Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-10-2004, 02:41 AM
rob68r rob68r is offline
Send a message via Yahoo to rob68r
testing ignition module?
Does anyone know if you can test an ignition module on a 93 bonneville 3.8 liter ? I called autozone and they said they could not test that one.I'm not getting any fire from coils.THANKS
Old 04-10-2004, 09:25 PM
int_53185 int_53185 is offline
did u get any codes from the check engine light or a scanner>?
Old 04-11-2004, 07:55 PM
Re: testing ignition module?
Yea I'm Getting a 42
Old 04-11-2004, 08:01 PM
I'm stumped here in michigan.I tried a new crank sensor,a new camshaft sensor,and i put on a used ignition module from salvage yard.[Not sure if its good or not] I really did not want to spend that much money to get a new module if thats not the problem
Old 04-11-2004, 09:38 PM
code 42 is bad ignition module..id try another one....
Old 04-11-2004, 09:42 PM
Ok I'll try
Old 04-11-2004, 09:45 PM
had this happen at work...98 grand am...i believe the used one we got was out of a 2001..started right up...this is definately your problem...
