Old 04-09-2004, 11:20 PM
POScar49 POScar49 is offline
time for a new engine?
i got a 91 lx and the things been overheating since i got it. we've replaced all the cooling components and shaved the head. for some reason wen u press on the gas, all the coolant flows straight into the overflow tank instead of going into the engine causing the engine to overheat. then wen u release the gas, the coolant will suck back into the radiator and cool it down. its kinda of stupid but i dont know wats up with it. anyone got any ideas? broken waterpump maybe?
Old 04-10-2004, 12:35 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
This may sound smartass-ish, but really its not, I have no idea what may be goin on..have you tried takin it to a shop, or callin around to your local shops and explaining and seeing what they think might be the problem? Thats so wierd bro, keep me posted...
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 04-10-2004, 01:18 AM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
Re: time for a new engine?
i had a similar problem with my old engine, the head gasket had gone and in the end, exhaust was puching the coolant out the overflow, have you checked the thermostat? just an idea
Evan
Old 04-10-2004, 01:30 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
here is another one that I have been caught on twice. Once with a a6 and just recently with the z6 Run the car to temp at Idle make sure you have the coolent res. full. then crack the bleeder screw on top right before the top hose goes into the motor. Let all the air out. you may have to do it a couple times to get all the air out. What I think your getting if it is not a head gasket is air expantion (sp) as you rev of course your cyc. walls get hot any air in the system will expand more than water forcing water out cause the air is traped. Try that see if it helps ya out. Just from my experence.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
