Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 04-09-2004, 09:28 PM
thurmon thurmon is offline
jetta radio code
I just replaced my stock 98 jetta wolfs. radio with one from a local dismantler. dismantelerprovided the code and went to activate code and went to safe 2x still cant seem to code in the radio...any thoughts?
Old 04-10-2004, 10:00 AM
jmack17m jmack17m is offline
I had the same problem. I called a vw dealer and gave them the #'s on the right side of the radio in the rear, and they gave me the "correct" code. Hopefully they will have the right one for you.
Old 04-11-2004, 09:45 AM
K_millar K_millar is offline
I have a 1990 Jetta, I bought as a smash-up and new nothing about it.
When I put a battery in it I noticed the security feature. The car had no manual, but I found a card in the door that said VW Radio Security Code and a 5-digit number on it. I called VW to ask them how to input this code, and they said ALL vw's use only a 4-digit code, and the radio is only asking for 4-digits. I don't know how to explain this card.
KMillar
Old 12-29-2005, 04:54 PM
bzell bzell is offline
Radio Code Answer
Anti-Theft Coding
When you switch off the radio and remove the key, a red diode in the face plate will start blinking. This means that the
radio is in anti-theft code. The Anti-Theft Coding will prevent unauthorized persons from operating the unit if it has
been removed from the vehicle
Whenever:
· The radio is disconnected from the vehicle current supply
· The battery is disconnected
· The electrical fuse for the radio is blown or removed
The word SAFE will appear in the frequency display when the radio is switched on. The unit will only work again if the
correct code has been entered.
This code number and the radio serial number are on the “Radio Card” next to the table of contents in the front of the
instruction booklet. If you do not have the radio code, you must remove the radio, aquire the serial number on the radio
unit and call the local dealer for the proper radio code.
To cancel the electronic “lock-up” from the “SAFE” mode:
§ Turn on the radio and the word “SAFE” appears in the display
§ Press the MODE and SCAN buttons simultaneously and hold them down until “1000” lights up on the display.
Release the buttons! DO NOT under any circumstances continue holding them down or press them once
again. This will cause the radio to consider the number “1000” to be the input code number
§ Use the station buttons 1 thru 4 to input the code number on your Radio Card or the appropriate code for the
radio. Use the 1 to input the first digit of the code number, button 2 to input the second digit, and so on. For
technical reasons the first digit can be a 1 or left blank (making the first digit a 0. The following three digits, may
be any number from 0 thru 9.
§ Once the code is shown on the display, press the MODE and SCAN buttons simultaneously and hold them
down till the word “SAFE” appears in the frequency display.
§ Release the buttons! Soon afterward, a frequency will be displayed and the radio is functional again.
