Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-09-2004, 09:26 PM
parker1963 parker1963 is offline
heater core installation 97 Crown vic
Looks prettey much like the heater core is leaking.
I have no idea how to get to it. Is this a dash baord removal problem?
Old 04-12-2004, 11:22 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
It may be under the dash, I don't know for sure. But check on the firewall, there may be a bolt-in unit that you can get to from that side; if not you may be able to reach it under the dash, w/o removing, but that is a back/neck/wrist bending enterprise.
Of course, if you live far south enough, just take the output for the heater from the water pump and loop it back to the input, making a closed circuit and eliminating the core altogether. No heat that way, but you'll have time to work on it...if it's warm enough.
Old 02-12-2005, 04:58 PM
crownvic95 crownvic95 is offline
Re: heater core installation 97 Crown vic
You have to remove the dash to get at it. I am doing this as we speak.
Old 02-14-2005, 05:48 PM
Hi parker1963,
Check out this post on how to change your heater core. A lot more information there.
Crown Vic 5 speed swap, help jnslick Crown Victoria 2 07-10-2010 09:34 PM
04 PI Crown Vic Zeepian Crown Victoria 0 03-29-2009 01:54 PM
92' Maxima Heater Core Installation cflava Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-12-2005 12:59 AM
1985 heater core install... BigBadStang Bronco 2 12-23-2004 06:24 PM
1982 GMC heater core installation... pinkpanther206 Sierra 0 11-09-2003 06:03 PM
