Old 01-10-2002, 03:07 PM
jOYRiDe jOYRiDe is offline
what can i use from a lude front cut?
besides the obvious engine/gearbox/ecu, wot else can i use from the lufe front cut?? definitely not the dash... umm can i use the whole front suspension (is lude 5 lugs whereas accords are 4 lugs?)
is it even worth getting the front cut?
im thinking about buying my dads 94 ex accord (4door) and swappin the motor (h22a obviously)
Old 01-10-2002, 05:40 PM
JasonAccord98LX's Avatar
JasonAccord98LX JasonAccord98LX is offline
Send a message via AIM to JasonAccord98LX
I think some ignition components could swap over--maybe they are the same already. I'm not sure how the suspension it setup in comparison to the accord. I think you will also need a brake upgrade, im not sure if the lude came with bigger brakes than the accord. There are lots of tidbits that you need to be aware of, but i dont know them all. You might have better luck posting this in the "let's get technical" forum, where dudes like fritz, moppie, and drift could help you.
-Original PH Member-
Registered in May of 2001
'98 Honda Accord Sedan 2.3L VTEC 4cyl 5-speed
Generic Cold Air Intake
205/60/15 Bridgestone Potenza RE950's
Save the Oompa-Loompas.....a site I helped create
http://www.oompa-loompas.net
