Old 04-09-2004, 12:11 AM
BiggyD's Avatar
BiggyD BiggyD is offline
Question Whine
My TA when I go to turn corners slow will make a noticable whine. I have read about tranny whine and stuff but I don't think it sounds like that. I asked my dad and he said it was just because of the limited slip. I just want to make sure it's nothing major. It doesn't do it when I speed up or slow down just when I'm driving around town slow and turn. thanx
Old 04-09-2004, 03:05 AM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Whine
where is the whine coming from?
It could be your power steering fluid being a little on the low side. Check it
It could be the rearend(have you ever had the rear end fluid changed out? check this one too. 3/8s drive rachet and you can take the rearend plug out(top side on the passenger side of the pumkin). depending on the mileage on the rear, might want to have it serviced(fluid/new posi additive/etc) and DO NOT let pep boys, the dealership unless you know someone there or jiffy lube touch your car!
I'm assuming you have an A4(auto). I have a T56 but I've never heard a tranny whine in an Fbody. my 5.0 GT AOD would have a "hum" or "whine" in Overdrive on the interstates.....
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 04-09-2004, 08:20 PM
BiggyD's Avatar
The sound is coming from the back so I'm thinking it's the diff. I think I'm going to try to do it myself, but when I bought the car it didn't come with the owners manual so can anyone give me good instructions on how to change the fluid and what kind of fluid to use.
Old 06-10-2004, 02:25 AM
Bandit1 Bandit1 is offline
Send a message via AIM to Bandit1
Re: Whine
well first, i believe you loosen the gear housing and let the fluid drain out, then torque it to specs and refill if i'm not mistaken. Am i right DarkblueTA? For the fluid I would suggest royal purple gear fluid as I hear that stuff's pretty good.
Old 06-10-2004, 08:04 AM
Philo Philo is offline
Re: Re: Whine
If the rear axle is limited slip (it should be) make sure you put the correct fluid in it. There is a limited slip oil for this application. GM also has an "anti-chatter" additive for GM limited slip axles. If your axle "clunks" or feels like the rear end is trying to steer the car when going around corners (making a 90 degree turn in town for instance), then this additive will help. I would put it in anyway - it will also prevent the clunks.
Old 06-10-2004, 10:41 AM
DarkblueTA's Avatar
Re: Re: Whine
That's correct. I would pick up the manual for the car at autozone or your local auto parts place. Make sure you use ALL the fluids that they specify for the rear end. have fun putting in the fluid though because its a heavy fluid. I would jack the rear of the car up and put stands under the rear subframe(so the rearend will be free and stay "down" away from the car). This should help in draining the bottles of fluid in the rear. The plug you want to take out to check/add the fluid is on the passenger side. I think its a 3/8 rachet by itself should take it out.
Have fun changing it out
EDIT: DO NOT USE SYNTHETIC FLUID IN THE REAR!!!!!!!
DarkblueTA
