Old 04-08-2004, 07:53 PM
KaMaKaZiPyRo KaMaKaZiPyRo is offline
Send a message via AIM to KaMaKaZiPyRo
Stupid Q, need a Smart Answer
Ok seriously i dunno wtf the difference between cold air intake and just the air intake, and if I was getting and engine swap(1997 GSR Type R)for a 1995 civic would it matter what model I got, DX, LX, EX?
Old 04-09-2004, 02:52 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Stupid Q, need a Smart Answer
Ther is no GSR Type R, unless you meant GSR or Type R.
As far as the model, it doesn't really matter, except one may have factory options that you want. The EX has vtec already, so it will be one less wire you have to run.
A cold air intake is one that is routed through your chassis to the wheel well, and it does this to draw in air that is colder than the ambient air in the engine bay. A regular intake draws in air from the engine bay.
Old 04-09-2004, 01:10 PM
Ok tahnx for clearin that one up, I meant Type R
Old 04-09-2004, 01:33 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
What year/model Civic do you have?
If it's an EX there will be a hole in the chassis to run the cold air intake through. If you have the other models, you're either going to have to cut out that plate or contact AEM for a hybrid intake. They make intakes for engine swaps..
Like my engine, a Type R or Si intake won't fit because I have a metal plate on my DX where it would normally route. AEM makes one for my engine that will route around it to the wheel well.
Old 04-09-2004, 01:37 PM
Re: Re: Stupid Q, need a Smart Answer
Really, you didn't have the hole? I thought the stock resonator routed through there? Damn, my VX has the hole
Old 04-09-2004, 01:52 PM
Ricochet's Avatar
Banned
Do you have the horizontally mounted intake manifold?
Old 04-09-2004, 01:54 PM
Yea,
Ok, so the IM's that inlet from the top (vertical postion) don't have the hole in hte chassis? Weird, seems they'd punch it on the line when they made that partof the frame.
Old 04-09-2004, 02:00 PM
Ricochet's Avatar
Banned
Then the only sohc's with the shitty im's were the DX, CX and LX models. The EX, HX, and VX (hatchback only right?) had the nice horizontal ones, and the hole in the chassis.
