Old 04-08-2004, 07:14 PM
bcbosley bcbosley is offline
lowering springs
I want to lower my 99 GS and I have some question I hope someone will help me with. I dont want to spend the money on Eibach springs, what other springs are good but cheaper? What about Sprint? What is a good drop for an eclipse 1.5 inches or 2 inches or what? How do you know what degree of camber kit to buy? Help please.
Old 04-09-2004, 05:27 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: lowering springs
believe it or not, the tien springs are cheaper than the eibach. sprint springs aren't the best IMO. but thats just me. if you're going to do something, you're gonna want to do it right. If you do lower your car.. you will also need to buy new shocks for the car. by lowering the car, you put the shock under stress while it isn't even moving. thus when you actually hit a pothole or a bump in the road, the shock is "crushed" to it's max and it causes them to blow and then your car rides like a damn tank (trust me.. I know what tanks ride like) I personally would not lower the car more than 1.5, it's a little excessive after that and too hard to drive. but then again I have crappy ass roads. almost all camber kits are adjustable. buy one that is, and when you adjust your camber, just make sure the tire rides flat on the ground. that way you won't have uneven wear and the vehicle won't shake at high speeds. you may not even need one if you're only dropping it 1.5 inches. Good luck with your choice. for other spring sets and prices check out the dsm site list sticky and have a look around.
V8's are like tampons, every pussy needs one!
Old 04-19-2004, 11:20 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
I went with the tokico Illumina 5-way adjustable set (4 shocks 4 springs) msrp is about 1,100 but u can pic them up off ebay for about 700 or you can get the hp set for like 500. great suspension i am very happy with it.
Old 04-20-2004, 07:50 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
You can actually get the Tockico HP setup off of ebay for about 389.00 and 40 bucks for shipping. But I agree with every one else. You should do both shocks and springs at the same time. If not you will need to pay for 2 alignments. And if you dont your car will ride like crap. And trust me if you dont change your springs you will change them in a few short months. Especially if you lower your car more then 1.5 inches. If you go 2 inches you will repalce them in a few weeks.
Do it right one time only. Save yourself money in the long run.
Old 04-20-2004, 08:03 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
when i put my coils on i never got my car alligned... put a camber kit on and dropped it 4 inches, rides just fine. i can get up to about 120 before it starts to shake
Springs Made in Canada springman West Canada 0 12-01-2010 03:14 PM
Lowering Spring HELP! sentoyang Brakes and Suspension 2 10-23-2009 04:34 PM
lowering springs and front/back springs?? ynii_g Camry/Camry Hybrid/Vista 4 05-30-2004 12:28 PM
Ground Control adjustable springs VS. lowering springs AznDragon Tires and Wheels 3 02-17-2002 05:21 PM
