Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-08-2004, 05:18 PM
Oldteg Oldteg is offline
cheap performance
I have done a couple of small things to my car that were free mods. I asked a bit ago if there was a EGR valve on a 90 teg but got no answers. I wanted to disconect it and block it off. I don't seem to be finding one and I have heard that the 90 didnt have one. I made a custom CAI for about $25.( it dont look pretty but it works great.) I also went in and rerouted all the coolant lines to the intake. I now have no coolant running into and out of the intake Thus, cooler air going in. I plan on Getting an exhaust cutout for the car because Im cheap and I want the car to look stock. All I will have to do is pull the lever and my exhaust will be dumped. I may end up buying a cheap header. I also got rid of a big power robber, my power steering. Now all the car is turning is the alternator and water pump. I may also end up buying a chip for the car.
Now, this brings me to my question. I would also like to start playing with the timing. I want to advance it. Is this wise and what should I expect from it? I belive there is a lot of capability with these engines with little or no money at all. We get ripped off with all this emissions crap and detuning from the factory.
If someone could also let me know about the EGR, that would be great. Maybe if you have any other free mods or very cheep mods, this would be a good place to list it. Thanks in advance.
Old 04-08-2004, 08:52 PM
KounT KounT is offline
Send a message via AIM to KounT Send a message via MSN to KounT
Re: cheap performance
how did you get rid of your power steering
Old 04-09-2004, 09:23 AM
All I did was took the belt off.
Old 04-09-2004, 09:33 AM
kpsycho's Avatar
kpsycho kpsycho is offline
yes just advance only 2 degrees i believe though check out www.g2ic.com for tons of hints and tips but make sure you search the forums first and check out teg tips
Old 04-09-2004, 12:02 PM
Talking Re: cheap performance
Great, any other tips out there or are you all keeping them to yourselves?
Old 04-09-2004, 12:06 PM
Re: Re: cheap performance
I will be getting rid of the whole thing very soon. I'll let you know how to do it as soon as I do it. For now, the belt is good enough.
Old 04-10-2004, 03:00 PM
integrasedan integrasedan is offline
1. Homemade hyperground wires. makes the engine rev smoother, slight better throttle response, but overall, idles better.
2. Check proper tire pressure, most people are low. you will get better gas milage.
3. If you have non gsr and advance timing use premium gas, if you have gsr then add an octane booster with premium gas. advancing timing will give better response.
4. If you plan on getting the chip, skip the timing advance, since the chip will advance the timing for you.
5. Use a higher pressure radiator cap, better cooling means better.
6. Change fuel filter and add fuel injector cleaner, will make car run good.
7. Adjust the throttle line so little slack, but not too tight or high idle. quicker throttle response, and or get weapon R throttle rotor.
Old 04-12-2004, 11:27 AM
I just bumped up the timing and I am very pleased with the results. I may be tinkering with the stock fuel pressure regulator to bump it up a bit. I think this is a fun project considering I am into the bigger motors on the domestic cars. I am also happy that I have next to nothing into the car for money. Hey my mods are not pretty but they seem to be making a difference. I will keep you all posted on the budget integra car. This should be fun.
Old 04-12-2004, 05:44 PM
how do you bump up the timing now?
Old 04-13-2004, 10:15 AM
The best thing for you to do is get a haynes manual and make sure you have a timing light.
1. loosen up distributer bolts
2. start car and hook up timing light.
3. turn the distributer just a little bit and watch your timing marks. I advanced mine by 3 degrees
4. tighten up the bolts again and take it out for a spin.
5. listen for any knocks or pings
6. run premium fuel
I would buy a manual for sure before you do it. It will explain it to you in detail rather than how I am on here. you can pick one up for $15 at your local parts store. I just read it every night and it gives me tons of ideas.
Cheap performance upgrades cajunkonection Neon | Plymouth Neon 12 02-07-2005 10:55 PM
Cheap performance upgrades brots06 Grand AM 3 06-28-2004 10:33 AM
Cheap performance for 305 caprice84 Caprice 7 06-26-2004 12:41 PM
Where can I get cheap Performance Parts Online? devenmustangracer Mustang Talk 11 11-28-2003 01:53 AM
