Old 04-08-2004, 04:03 PM
bluebowtie bluebowtie is offline
Batt Or Alt?
Let me try to explain my situation the best I can.... I own a 2000 silverado.5.3l. I have installed a stereo sony cdx780 head unit, with 4 volt pre out, and a kicker amp ix402. Running 8 gauge wire from the battery to the amp, fused 12" from the battery.Grounded to the chassis 18" fro the amp. Running 2-12" bostons, the amp is bridged. I have a stock battery 600cca and 300 Load test? Stock alt,putting out 105 amps. I am having voltage drops.I can see the voltage gauge in the truck drop and go down. when i leave the truck sit for a long period of time the voltage is up, as i drive and play the stereo it drops low and lights dim. And the amp is unable to get the required current and sounds different. I have done a test on the alt and it is putting out 14.4-14.5, 100% working, now my battery is at 70% not running and drops slowly when the stereo is playing(hard)which it is going to do !. So what do i need to do? I can upgrade the alt to 145 from 105. I am wondering why such the voltage drops?. Could it be that my alt is slipping on the pulley when the load is put on it or when it gets warm would it give out,or is it able to handle the amp draw, or is my battery so low that the alt doesn't have time to replace the used voltage.? What should I do? replace the battery with a new one? and what type, size. And if i just upgrade the alt would it help the battery(stock) that is in it work better? When i decide to do something I will also upgrade the grounds and power wires to better handle the draw from the amp.I am stuck at a spot where i have no idea what to do. I know everything costs money, however I want resolve the problem i am tired of wondering what to do. Does anyone have or had this issue and what resolved it?..
Bluebowtie
Old 04-09-2004, 10:41 PM
droptop94 droptop94 is offline
Re: Batt Or Alt?
you are pulling more power from your battery is used to start your truck and to help your alternator under extreme conditions. which it sounds like your stereo is putting on your electrical system. you can get a heavy duty alternator , but I would start buy getting a capacitor. you can get them at the stereo store. you will proudly spend around $100 or so, but this should help you tremendously. stop buy a stereo store and ask them about the capacitor and how to hook it up.
NOT charging, new alt & batt. SteVB Catera 6 01-30-2007 04:45 AM
Volt light on - Alt & batt OK 1regal Bonneville 2 11-04-2006 06:36 PM
Batt to Alt. Wire Rs051802 C/K 0 01-06-2006 11:18 PM
dealer replaced alt, then batt, still have problem Henrik Escort 8 03-31-2005 07:51 AM
Alt or batt? bluebowtie C/K 7 04-14-2004 12:54 AM
