Old 04-08-2004, 01:15 PM
eswaroop eswaroop is offline
Disconnect o2 sensor -> better performance?
Hi,
My car (99 accord ex 4 cyl) seems to run better the first few minutes but as it gets to normal op temperature, the power and acceleration seem to go down. I was wondering if the 02 sensor is bad and messing things up when the car goes into closed loop( when it reaches normal temperature).
Would it be a good idea to just disconnect the o2 sensor and see if the car runs the same even if it warms up, so that I can conclude that the o2 sensor may be the culprit? I know that the CEL will come on but any other issues?
Thanks
es
Old 04-10-2004, 08:46 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
Re: Disconnect o2 sensor -> better performance?
its only a 99 so it shouldnt be bad, is the fuel system modded any?
Ya, It's Turboed.
Old 04-11-2004, 08:28 PM
No, no mods. The problem started after I had a valve adjustment done to the car. Thy adjusted the valves too tightly. I corrected them back to specs, but that does not seem to have fixed the problem. I am guessing it could be burnt valves...
Old 04-12-2004, 12:22 PM
jeffseby's Avatar
if everything is a stock honda, I dont see what the prob can be. I'd just let a pro look at it. sorry.
Ya, It's Turboed.
Old 04-13-2004, 06:07 PM
integrasedan integrasedan is offline
I think running the car without the oxygen sensor will not make the car run better.
Old 04-18-2004, 11:57 PM
valleydude valleydude is offline
The whole purpose of the engine sensors is to send information to the ecm. The ecm creates optimum performance using this information.
Old 04-19-2004, 12:03 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
pulling off an o2 sensor= check engine light
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 04-19-2004, 11:23 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
when my 02 sensor went bad the car would have a weird idle. and then it would ultimatly die. So dont disconnect. Its there for a reason.
Old 04-20-2004, 03:45 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
The bottom line is it's bad. Pulling the O2 sensor will almost always throw the car into "limp home" mode where it retards the timeing, and really richens the fuel flow, because the ECU now thinks that there is something wrong with the car. It'll cause weird idle, and decreased performance, as well as kill your cat converter much faster because the motor is running much richer on the fuel causing increased emissions.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-20-2004, 05:52 AM
redmanjd redmanjd is offline
you need your o2 sensor it maintains your fuel ratio. When the car is cold the 02 is in closed look(.435 v) until it warms up then it goes to .750 to .800v , that is if you are running a 1 wire 1volt o2. The reason your car runs better cold is because the air entering the engine is colder so your car will be faster. Bottom line dont disconnect your 02 or you will run lean
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
