Old 04-08-2004, 08:50 AM
rstang rstang is offline
car wanders
I've recently replaced the front shocks and driverside balljoint on my 90 GT and now the driverside tire leans in at the top. This causes the car to pull to both sides with out notice. I've been told to put on the adjustable caster/camber plates. What I don't understand is what will cause the tire to lean in. The other tire sits just fine.
Old 04-17-2004, 08:27 PM
price111 price111 is offline
Re: car wanders
My first guess is something in the way you replaced your ball joint? Otherwise, the tire should sit pretty much as before. These cars only have toe-in/toe-out adjustment. There is are three holes in the top strut plate but this should be preset from the factory.
Did the tire sit that way previously?? If not, I'd look at your balljoint repair.
The front struts have nothing to do with alignment. There are just two bolts to the knuckle and can only go in one way. I've done that job on my (previous) '92 LX.
It's hard to imagine why you have so much camber like that unless it has something to do with your repair?? Has the car been in a front end accident? I ask for a reason.
LOL
Old 04-18-2004, 01:56 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Get some C/Cs have an alignment done, and you are good to go.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-18-2004, 10:53 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: car wanders
thats best bet imo.
after getting suspensoin work done things being a lil goofy can happen sometimes.
