Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-08-2004, 08:13 AM
panoman88 panoman88 is offline
97 SSEi - maintenance of supercharger
Does the supercharger need any maintenance like changing the oil, etc. My SSEi has 105,000 miles. If the oil can be changed what kind do you use? Thanks in advance for your response!
Old 04-22-2004, 09:10 PM
62rod 62rod is offline
Re: 97 SSEi - maintenance of supercharger
just keep it full of oil. it uses a synthetic oil which you can buy at a GM dealer, it's about $6-$8 dollars for a 4 oz. bottle. there is a plug toward the tip of the supercharger that takes a 3/16" hex bit (allen head).
the life expectancy of the supercharger is about 80,000 miles.
Old 04-23-2004, 10:15 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The oil should be changed every 30K miles per the maintenance in your owners handbook.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-29-2004, 02:14 PM
wesley1959 wesley1959 is offline
Re: Re: 97 SSEi - maintenance of supercharger
Ok so I have a 96 SSEI with 157K miles on it. Should I be worried even though its running perfect? Is there anything I can look for to tell me that the SC is going bad.
Thanks
Old 05-02-2004, 07:51 PM
daman daman is offline
80,000 MILES!!!!, give me a break, they last a hell of a lot longer than that mine has 140,000 and as quiet as the day it left the showroom,and i've seen many go longer than 80K, with proper maintaince they'll go the distance.
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 05-13-2004, 07:57 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
when i first got my 95 ssei, one of the first things i did was get the supercharger oil changed. because it only takes one four ounce bottle to fill, all i had to do was hook up a vacuum pump to the little hole, suck the old 4 oz out, and pour the new stuff in. even if you had it done by someone else, $30-$40 seems very little so spend to ensure a smooth running blower.....
