Old 04-08-2004, 07:45 AM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
Thumbs up Great Results
Last night I installed my FIPK2 and cleaned my throttle body,also cleaned my MAFwithout screen (w/contact cleaner) the whole job took about 1hr, after what a difference!! at first it didnt feel much different but after about a half hour of driving I could feel the difference in Power. I swear My exhaust got a bit louder as well (could just be my imagination) before my throttle used to stick here and there and it operates much smoother.. Not only does the Intake look sweet but the sound and performance are well worth the money.. I wish I did it sooner! I think my next Mod will be a Hypertech.
Id like To thank everyone at AF for their input and ideas!
Thanks Again!
-Jimmy
Old 04-08-2004, 10:52 AM
buttnekked buttnekked is offline
Re: Great Results
OK, I thought it was just me. My exhaust seems louder since I cleaned the butterfly and removed the maf screen. I've got a drop in k&n now but I definitely want to try the fipk and the spacer for the throttle body.
Old 04-08-2004, 12:05 PM
yankeeintruder yankeeintruder is offline
Re: Great Results
buttnekked........... double check me but I'm pretty sure you can't use a throttle body spacer with the K&N FIPK. When installing the K&N kit I'm familiar with (#5730211), you must trim some of the fan shroud for clearance of the inlet tube.
If a throttle body spacer is used in conjuction with this kit, the blades of the stock cooling fan will hit the inlet tube. A way around this might be the use of an electric cooling fan.
K&N has a new kit I believe that uses a metal inlet tube (if one is available for the Silverado) and maybe this clearance situation has been addressed. Good luck!!
Old 04-08-2004, 12:11 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Great Results
No. you cannot use a spacer with the FIPK..the intake tube fits against the fan shroud without it. If you interested in cutting your shround it might can be done, but also check for fan clearance so it doesn't hit the intake tube. I've seen a stock intake tube used in conjunction with a K&N heat shield and filter, and the spacer fit fine...go figure??
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-09-2004, 05:27 PM
jonjonwells jonjonwells is offline
Send a message via AIM to jonjonwells Send a message via MSN to jonjonwells
I have installed a K&N with a throttle body spacer. It did require the romoval of the stock fan and the trimming of the fan shroud. Also, with this combination you will have a sucking sound everytime you hit you gas at less than wide open. I personally like it, but some people don't. Just FYI.
Old 04-09-2004, 10:51 PM
Re: Great Results
thanx guys. Guess I'll go with a spacer while I save pennies for the fipk.
