Go Back   Automotive Forums Car Chat > Lamborghini > Gallardo
Old 04-08-2004, 05:45 AM
Peter Stingray Peter Stingray is offline
Gallardo rims
Hello does anybody know the specifications of the gallardo rims,what I wanna know are the whole and offset numbers,for example front 8.5x19" 5x112 ET37 and rear 11x19" 5x112 ET 42,sure that are not the right numbers but if anybody know thanks a lot!
BTW could someone give me some links for pretty aftermarket rims but only for the gallardo,I have searched a lot but nothing found for the gallardo.
Bye!
Old 04-08-2004, 07:31 PM
Powerchipgroup.com Powerchipgroup.com is offline
Banned
When l was collecting my Gallardo a few weeks ago l was told not to put any after market rims on the car....the reason was it will void the drive train warranty as the cars all wheel system has been calibrated for those wheel and tire combo only. I don't know it thats 100% true, but to find wheels that match the edges and shapes of the Gallardo will be very hard. I'm not going to bother with after market wheels, as l feel these are a great match for the cars stlye.
I does look like the tires could be 20mm wider on all corners.
PC
Old 04-09-2004, 01:45 AM
Thanks PC,but actually I wanted to know the specifications of the rims (the diameter of the wholes is 5x110 mm or 5x112mm or what?),yes I agree that the standard are the best choice for safety when you drive very fast because the factory has tested with it,but for slow cruisin there are not cool enough,they have no special design and it if you own a black then you have to own darker wheels then the standard,it looks like on an Audi S4 and on MTV cribs I have seen so pretty wheels on a black Gallardo for a rockstar I think it was Travis from Blink 182 and he has get it from someone from NY,I wanna know who sells them there,what would speak against it if I would have two sets of wheels one for racing and one for cruisin,I mean you dont drive every day like Schumacher,isnt it?
Bye!
Old 04-23-2004, 01:12 PM
BobChow BobChow is offline
Arrow
Find this:
Old 05-08-2004, 07:03 AM
Banned
I don't think the total height of an after market wheel/tire addition to the Gallardo can be much more then 5-10mm larger or smaller then the OEM specs.
A new tire and a worn out one have a difference of 15-20mm in total height as it is, but what is the limit l wonder?
The drive line is built for that OEM radius so to change it dramaticlly would get us in plenty of trouble with warrenty....it's happened before when a guy changed his set up and melted the front end for a cost of $25k...I think it was a Murci
If l was to get my car to the track a bit more l would like to drop to 18 inch slicks for those days...that would be fun.
I must say Bob Chow, that pic you posted looks great, but l don't think l could go chrome.
PC
Old 05-12-2004, 01:40 PM
sdowney sdowney is offline
try giovana wheels. they make everything custom. i am not sure if that is how you spell it but it is close.
Old 05-12-2004, 06:40 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
Re: Gallardo rims
Structure : Structural alumnium space frame, based on aluminium extruded parts welded to aluminium caster joint elements
Body : Aluminium with thermoplastic 'hang on' parts
Suspension : Double wishbones front and rear suspension, anti-roll bar, anti-dive and anti-squat 'self adjusting' Koni FSD dampers
ESP : Full ESP system with ABS, ASR and ABD
Brakes : All wheel ventilated discs, power vacuum, aluminium alloy Brembo calipers : 8 cylinders front caliper and 4 cylinders rear caliper
Front : 365 x 34 mm
Rear : 335 x 32 mm
Steering type : Power-assisted rack and pinion, 3.2 turns lock to lock
Turning circle : 11.5 m
Front tyre size : 235/35 ZR 19
Rear tyre size : 295/30 ZR 19
Type : Pirelli P ZERO 'ROSSO' with asymmetric unidirectional tread
Front rim size : 8.5 x 19 inch
Rear rim size : 11x19 inch
this was from lambocars.com , i hope it helps
Old 05-19-2004, 03:25 AM
Thanks a lot but all this I have know before,I wanna know this numbers for example 5x100 or 5x110 or 5x112 or 5x120 or what,and the ET numbers and that are numbers that nowhere stands and just real specialists know!
Bye!
