Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 04-08-2004, 01:20 AM
ragnarok720 ragnarok720 is offline
Rims
I've never been a rim guy so i don't know exactly what rims will fit nicely on what car such as offsets and all of that. I was curious though to the people on here that do, will the tenzo mach-10 rims fit on my 02 wrx?
Old 04-19-2004, 05:46 AM
Re: Rims
Anyone here know anything about rims?
Old 04-19-2004, 07:59 AM
freakray freakray is offline
AF Modelrater
Re: Rims
Did you try the rims and tires forum?
AF User Guidelines
Old 04-20-2004, 01:29 PM
nhibbert nhibbert is offline
All Subaru's use Hubcentric rims with a 5 x 100 bolt pattern and a +52 offset (OEM). People use often use aftermarket rims with offsets in the +45 to +48 range. I don't know if the Tenzo Mach 10's come with that setup.
This is an old link - last updated in 2002 - but it gives you a good list of rims that are known to fit. http://wac.addr.com/auto/obs/wheels.html
Old 05-24-2004, 02:03 PM
winner155 winner155 is offline
19 by 8 with a 30 mm offset will NOT work. Got that on my 03 WrX and the wheels rub the fenders over bumps. Going to try 19 by 8 with a 45 mm offset if I can find them next.
Old 06-17-2004, 06:54 AM
cche2052's Avatar
cche2052 cche2052 is offline
Re: Rims
Will fitting higher profile rims and tyres affect the accuracy of your speedo?
Old 06-17-2004, 07:13 AM
AF Modelrater
Re: Re: Rims
As long as the outside diameter of the tire is the same it won't effect it.
AF User Guidelines
Old 07-02-2004, 06:36 PM
king4you king4you is offline
mach 10s
hey dude go with the mach-10s.they will look clean on your wrx.
