Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-07-2004, 11:17 PM
SMoOtHSTuNNA SMoOtHSTuNNA is offline
Talking Need suggestions for CivicHatchGSR
hey wassup y'all..i gotta civic hatchback with a 96 jdm gsr imported from japan. i got some goodies in there like intake, exhaust, headers, fuel rail, fuel pressure regulator, new clutch, lsd tranny, and a apex i vafc...i wanted to know what would be some good internals to place into my motor...i was thinking je forged pistons, rods, etc....what else could i do??? oohh yeah, could someone tell me how to set my vafc to make my car to its fullest potential. i only messed with the vtec setting, and some other settings.
Old 04-08-2004, 01:48 AM
SPNCRX SPNCRX is offline
Re: Need suggestions for CivicHatchGSR
It will best if you take your car to get Dyno tuned in order to set your VAFC the right way. I sugest you get some cam gears.... If you are thinking about building your short block make sure you get wut you need based on the cams u will be useing.(N/A). If your on a budget, get you some CTR cams, skunk2 IM, ITR TB, and Cam Gears. This will defently wake up your engine
Old 04-08-2004, 08:37 PM
coo...thanks alot...yeah im thinking of building my short block, just to make a quick all motor...my friend jus put a b20 block in his hatch...with others and he ran a 12.8...ima trying to get into the 12's...without going turbo...do you think that the gsr can get that quick...if not then ill jus be happy with low 13's...
Old 04-09-2004, 12:25 AM
There are lots of 12 sec All Motor GSR Street cars hear. You just have to do your homework first. theres more to it then just having a strong engine.. If you want a 2.0 you can resleve your block and it will be alot better then a b20 block. B20's are known to have weak cylinder walls..
Old 04-10-2004, 12:21 AM
lots of 12 sec GSR street cars huh?...coo that gives me big hopes...yeah i know i gotta research and learn more about my engine..im not worried about my driving either because i think im pretty decent...
Old 04-10-2004, 01:59 AM
strodda strodda is offline
first i would recommend putting your vafc settings back to zero. blindly messing with afr isnt very smart. and what kind of header do you have? no matter what internal work you do, you gotta have the right header to get the max potential out of it. try getting a jdm 4-1 or something similar with a 2.5ish collector.
there are more things than just internals you need still...but heres a simple list of power makers:
-pistons
-intake manifold(get rid of iab's)
-throttle body
-cams(stage2-friends put in skunk 3's in their racecar, made 2hp more)
-upgraded valvetrain to go with cams
-p&p head
Old 04-12-2004, 04:29 AM
thanks 4 the list...i got a skunk 2 4:1 header and a 2.5 collector...what type of pistons should i get..cuz i want pistons that would be best for an all motor...i was thinkin about gettin JE forged pistons with crower rods.....
Old 04-21-2004, 04:55 AM
CVTodd1 CVTodd1 is offline
Je forged pistons, and crower rods are a good choice, but i agree with strodda, intake manifold, throttle body, p&p head, etc are very good upgrades, especially if you already have intake, header, exhaust, adding on those additional parts, plus cams, and you'll be very satisfied
Old 04-21-2004, 10:17 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Stoick kitchen magnets on your block, mad titeeee jDm horsepoWer y0!!!!1!!
Need suggestions for traffic violcation smallball129 Traffic Violations - U.S. only 4 06-05-2004 05:11 PM
Need suggestions for braided hose and wire sizes..... Deejay27 Car Modeling 2 12-20-2003 10:11 AM
Need Suggestion for Shock VetteMan Engineering/ Technical 1 02-23-2002 02:57 PM
Need suggestions for good wet traction tires. Marc-OS Tires and Wheels 5 01-29-2002 04:33 PM
Need suggestions for wheels 02G20 Sport 02G20T Tires and Wheels 4 05-12-2001 11:14 AM
