Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-07-2004, 08:59 PM
willstoyz willstoyz is offline
Unhappy 1997 regal gs stalling
I have 1997 Regal Gs that died in the parking lot. I changed the fuel filter but it didn't help a whole lot. It starts fine, idles for 5-10 seconds and dies. It will stay running (or driving) if throttle is half way down or more. I got it home in 2nd gear by keeping the throttle half or better, it wasn't fun but it beats a tow. The abs and service engine soon light were on during the trip home ( I had to restart the engine several times ). Those lights are not on in park or neutral revving the engine. Any help would be greatly appreciated.
Thank you- Willstoyz
Old 04-09-2004, 08:20 AM
pcv pcv is offline
you need to scan the system for codes and hopefully that will lead you to the right diagnosis. Fuel pressure and/or sensor problem is causing your problem. Get it scanned and post the code/codes.
NOTHING LIKE AN OLD CAR.
Old 04-10-2004, 11:31 PM
Skavoovie Skavoovie is offline
Re: 1997 regal gs stalling
Try checking all the vacuum lines on the throttle body. A buddy of mine disconnected one while working on his GS and it would start, putter and die without extra throttle within a few seconds.
Old 04-21-2004, 09:08 AM
pricerj pricerj is offline
Hi, I have a friend with a GS that is having the exact same problem (right down to the it's stuck in the parking lot!) ... What was the fix ?
Old 04-21-2004, 10:02 AM
OK, found the fix. It's a resistor that controls fuel pressure at idles speed. Here is a link to the Website that posted the 'fix'. I tested it by jumping the resistor and the car runs fine. Replacement is 40 bucks at the dealer. A tip not clear in the article is this resistor is easily accessed from underneath the passenger side of the car in front of the wheel well above the plastic. The resistor is a white ceramic block mounted to the framerail.
Here's the URL ... http://www.smpcorp.com/download/view/Tt4Q99.PDF
Disabling Automatic Headlights - 1997 Regal GS TrinaR1231 Regal 1 12-04-2010 05:37 PM
Car Starts then stalls and POP! lixar420 Venture 21 01-09-2010 03:30 PM
Another stalling problem (95 GS) Cmal Regal 3 12-12-2009 02:41 PM
1991 Regal Ltm. Problem Shadowhax Regal 1 03-06-2009 11:19 PM
1997 Regal Jalegra Regal 2 02-03-2003 06:56 AM
