Old 04-07-2004, 07:43 PM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
Car keeps over heating
The dam camaro keeps overheating.. but.. only on the highway.. it will slowly start to climb to and pass 240 before i shut it down. But if im in traffic or here in town.. its only 220 and stays.. it started 2 days ago. usually it would run about 160-180 (160* thermostat, which i replaced today). Both radiator fans are on, and the fluid is full.. If im on the highway and i get off an exit and sit with the engine idling. the temp will start to go down, but its still running hot. Any idea's?
Old 04-07-2004, 08:17 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Car keeps over heating
thats seems horribly backwards from anything that should happen...
Old 04-07-2004, 08:21 PM
i know... it pisses me off something fierce im out of idea's.. well .. one left.... someone at work suggested it... it will cost me ... i think 2.05$ if i want the job done right... a gallon of gas.. premium.... dump it on the car and stand back
Old 04-07-2004, 09:18 PM
maybe its the control swich.. or the relay swich... maybe giving me a false reading.... becasue yesterday the engine read 260F... in the red... but i remember there was no steam or bubbling from the overflow or the radiator......
Old 04-07-2004, 11:06 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Did you check the water pump to make sure it's working properly?
You didn't say anything about that, it's the only reason I ask...
Old 04-07-2004, 11:56 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Sounds like it could be a bad pump..
Your rad or coolant lines could be plugged somewhere.. make sure your rad cap is working properly and your overflow levels are as they should be..
Other than that, im gonna say bad temp sender?
Old 04-08-2004, 01:31 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
yea maybe your water pump is pumping enough water at the higher rpms
Old 04-08-2004, 01:47 AM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: Re: Car keeps over heating
It sounds like you might have air in your cooling system. I have had this happen on a few cars.
What engine are you running? If it is the LT1 there are air bleeder screws in the smaller radiator hose and on the thermostat housing. Run you car for a while and let it get up to operating temp then shut it off and let it cool then open the bleeder screws. If air comes out this should fix your problem, but if it doesn't and anti-freeze comes out you have another problem. I was banging my head against the wall when it happened to me.
Old 04-08-2004, 07:36 AM
its the L98 engine.. no air in the system.. checked that yesterday.. Water pump... hmmm... didnt check that... what sound would it make when its on its way out? And how do i check to see if its working right?
Old 04-08-2004, 06:28 PM
ok ... i replaced the water pump today... still heating up... replaced the thermostat.. still heating up... flushed the system.. still heating up.. got any air ouft of the system.. still heating up. what do i do? it heats up on the highways... or above 45.. and cools down in traffic... wtf
Old 04-08-2004, 06:45 PM
is your radiator clogged?
Old 04-08-2004, 07:02 PM
how do i check to see if its clogged.?
Old 04-08-2004, 07:05 PM
well you can check to see if the fins are clogged with dirt and little rocks and stuff by removing the support and fan shroud, and you could prolly check the channels by unhooking your radiator hoses and spraying a hose down into it... maybe someone on here will know of a better way
Old 04-08-2004, 07:06 PM
no the fins and everything are fine... i dont get it
Old 04-08-2004, 07:08 PM
hmmm...thats a doosey of a problem
