Old 04-07-2004, 06:43 PM
maverick27 maverick27 is offline
Send a message via AIM to maverick27
how fast can a 20g be on FF?
hey guys i know ff vs awd is a huge disadvantage but how fast can i get my gst with a 20g??
Old 04-07-2004, 06:48 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: how fast can a 20g be on FF?
i think that FWD is consistently like .3 slower than AWD most of the time. it may be closer to .5 slower. i can't remember exactly. it was probably like between .3 and .5 slower...lol... so take your faster AWD times and add like .4 to it. i would say somewhere in the 12's.
Old 04-07-2004, 07:21 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
www.dsmtimes.org
look at all the 20g's on the FWD chart, then plan on being somewhere between those.. depending on how decked out your car will be,
Old 04-07-2004, 07:36 PM
awesome appreciate the help as usual guys. you guys are awesome. as for my car i plan on the 20g basic stage 1 upgrades dont want to get to crazy its just a fast daily driver but i want it for kill on the high way? how will i do at the high way say with the 20g???
Old 04-07-2004, 10:34 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
a bigger turbo isn't going to get you any more top speed... thats in your transmission and gear ratios. the turbo just helps you get there faster. but a 20g is a good turbo. You might want to look into the evo if you're gonna be doing more street style instead of drag racing.
V8's are like tampons, every pussy needs one!
Old 04-08-2004, 04:22 AM
kjewer1 kjewer1 is offline
AF - Advisor
A 20g FWD on the highway will be no worse off than a AWD with a 20g. In other words, it will pull you along nicely
Turbo size can affect top speed, when you consider that the smaller turbos wont make enough power to overcome wind resistance at high speed and max out 5th gear. Once you have a turbo than can take you to redline in 5th gear, then you are correct. Its all gear ratios after that point (and more power to turn that taller gear )
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
