Old 04-07-2004, 05:32 PM
maverick27 maverick27 is offline
Send a message via AIM to maverick27
intake question
hey guys i was wondering: is it nessesary to change the air filter to a k&n or should i just go out and buy the piping from the turbo and get a full intake system??
Old 04-07-2004, 05:49 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: intake question
If you get the piping or not, the K&N still helps the same amount. You'll be putting the filter onto the MAS, so getting a new intake pipe doesn't affect it.
Old 04-07-2004, 06:16 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: intake question
the K&N FIPK is at the top of the list for air filters. you can run the K&N with a dumptube hack for a pretty noticable gain. check out the POSR Home Depot intake for an extremely cheap, extremely effective intake pipe.
Old 04-07-2004, 07:32 PM
Re: intake question
well i plan on running at 20g a lil later so im just preparing my car for that so will the stock pipe be good should i make the home depot pipe like 95gsxracer or should i be a dijon intake pipe with the k&n filter
Old 04-07-2004, 07:50 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: intake question
Home depot and then spray paint it with the "ceramic" paint. Helps keep the heat out.
For Sale 98 Eclipse GS, 5 spd
Old 04-08-2004, 02:03 AM
youngmanvr4 youngmanvr4 is offline
Re: intake question
I was looking at getting the Injen intake system.I'm looking at getting a T3/T4 turbo system later on...but will the Injen system work with stock then later can i put the t3/t4 and will it still fit?
Old 04-08-2004, 07:18 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: intake question
I have the Injen intake system and love it. You wouldn't believe how much it changed the sound of the turbo and BOV. I had the intake, DP and high flow cat done at the same time (So I'm not sure which one exactly altered the sound). You can really hear the turbo spool up, and the BOV sounds more like a blitz...with that real deep wooosh! Plus it just looks nice.
Old 04-08-2004, 02:04 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: intake question
to answer dsm97gsx's question, yes... the injen will fit perfectly fine on the stock turbo. and it should also work just fine on the aftermarket. it just may be a little more difficult to squeeze the on. not a big deal though.
V8's are like tampons, every pussy needs one!
Old 04-08-2004, 03:21 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: intake question
Depends on the compressor inlet size. They can get pretty large once you start talking about Garrett hybrids.
Basically, anything smooth and airtight is going to be better than the accordian hose that came stock.
Kris
2012 Genesis Coupe 2.0t
