Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-07-2004, 05:21 PM
SLOlude SLOlude is offline
Negative Camber....PLEASE HELP!!!!
Sup guys I own a 98 SH and got it slammed with an H & R sprt spring kit. Lowered it about 1.8 inches and the fool I got it from said camber kit was not needed. Well now its been about 9 months and already went through the two front tires. I took it down to a shop and found out i have a 2 and a half degree negative camber. So my question is, whoever knows, is the camber kit I get a simple ball joint or on the SH do i have to get upper control arms replaced. Arms or ball joint? I've heard either will work but heard that the ball joints are not as reliable under heavy driving. Need HELP PLEASE!!!Thanks guys SLOlude
Old 04-07-2004, 11:46 PM
del del is offline
móddə rąytər
Re: Negative Camber....PLEASE HELP!!!!
i wouldn't think you'd need a camber kit with the h& sports. did you ever get an alignment on your car after you lowered it?
Old 04-08-2004, 12:41 PM
i didnt get an alignment.......which i know sounds stupid. So a simple alignment could take care of that much negative camber? If that's the case then I'll get it aligned and see what happens. Thanks
Old 04-08-2004, 02:26 PM
del del is offline
móddə rąytər
no, it wont' take care of the camber but it could eat up your tires pretty fast if you're not aligned right. what part of the tires are worn?
Old 04-08-2004, 05:31 PM
dbebesi's Avatar
dbebesi dbebesi is offline
maybe this will help.... i lowered my car..... it squeaked, handled poorly, had 3.5 deg neg camber, and was raping my tires in like 200 miles. i put a camber kit on last week, got it aligned (today actually), and no more squeaks, handles like a ferrari (guessing, never driven one), and i am EXTREMELY happy with it now.
note: i had 3.5 deg neg camber with a 2.75-2.50 drop, however. your's wouldn't be that bad.
Old 04-12-2004, 01:26 PM
The inside of the 2 fronts were worn bad. I don't drive like a grandma so my aggressive driving could be a huge factor. I know I probably need a camber kit, it's just people have been telling me there is no kit for the SH. Like the kit is just a ball joint on the upper arms that is replaced. And a few guys said they stopped selling it. If you knew what kind of camber kit to put it would help. Thanks
Old 04-13-2004, 12:01 AM
510prelude 510prelude is offline
Re: Re: Negative Camber....PLEASE HELP!!!!
did you put new controls arms on or ball joints? and how much did it cost? and did you do it urself?
Old 04-13-2004, 05:32 AM
dbebesi's Avatar
eibach camber kit x2
Summit Racing $129 each
each kit does two tires
the kit itself is two goofy looking bolts that replace the mount bolts in the upper control arm. then is adjusted by a wrench style dial on the protruding part of the bolt. i put them on my self. i work on cars for a living however. it's not that terribly hard, but if you didn't know exactly what you were doing, it would be a pain in the ass.
Old 04-15-2004, 07:27 AM
whats your current camber degree your running?
Old 05-09-2007, 09:35 AM
bchisler bchisler is offline
Send a message via AIM to bchisler
is there even a camber adjustment on that generation. I got a 93 vtec, my camber is not adjustable without a camber kit
Old 05-09-2007, 02:34 PM
dblair dblair is offline
You need to get an alignment. They will adjust your toe, which also affects camber, and give you a read out on your camber. Just getting a camber reading without adjusting toe tells you nothing. When you know what your camber reads you can make a decision which (if any) camber correction kit you need. They come in different ranges for different amounts of adjustment.
Then install the kit and have it aligned again. Sure is a lot of stuff they don't tell you when you buy lowering springs!
