Old 04-07-2004, 04:08 PM
tuckman tuckman is offline
tire size?
Anyone know what size tires I can get away with on a 2000 Z71 silverado I did an add a leaf in the rear and torsion adjustment in the front????
Old 04-08-2004, 07:24 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: tire size?
I know 285's will fit without a problem at all. You might can squeeze 305's under there, but it'll be tight. I have also heard some rumors of 305's not working well with stock wheels, so might wanna check that also.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-08-2004, 09:47 AM
buttnekked buttnekked is offline
Re: tire size?
The same friend I talked to about my sidewall damage told me that 305's will require slight trimming even if the front is cranked up. The guy at goodyear also said the same;they had installed 305's for another guy and had to do some trimming. I think for the 305's you will need the 8 inch wheels instead of the factory 7. Some suggest 10 inch wheels but I been told anything wider than 8's will cause vibration problems on the front.
Old 04-08-2004, 12:37 PM
roblbenson roblbenson is offline
Re: tire size?
I'm running stock height on my 98 Z71 and I put on some Bridgestone Dueler A/T Revos 285/75/16 and they are the best tires I have ever owned. I don't know if your trying to go bigger for sure, but this size does look pretty beefy. I had the BFGoodrich A/T before and they are nothing compared to the Bridgestone. I highly recommend you take a look, heres a link http://www.tirerack.com/tires/tires....omCompare1=yes. Good luck.
Old 04-08-2004, 03:02 PM
Re: tire size?
Hey thanks for the replies I think I am going to go with the 285's any issues with the 75's on the stock rims or are you running after market rims?
Old 04-08-2004, 05:44 PM
Re: tire size?
should be ok with stockwheels. Here's a page I found while reading up.http://www.ntwonline.com/template.cfm?ID=7#fffff
Old 04-09-2004, 07:53 AM
jeverett's Avatar
Re: tire size?
75's will work just fine on stock wheels. I have 285/75's on my truck and have not had any hint of a problem (except for a decrease in gas mileage). I'm trying to find someone to trade my 285's to for some factory size tires.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
