Old 04-07-2004, 02:20 PM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
problem with b16a swap, engine code
I checked the ecu on my b16a swap, and i am getting an engine code. It is for the ICV, any ideas on troubleshooting, what would suggest to check?
Thanks, Evan
Old 04-07-2004, 03:14 PM
91zc 91zc is offline
Well first make sure the electrical connection is plugged into the sensor. Next the IACV has a little filter inside. You can take it out and clean it and see if that makes a difference. Otherwise you are going to have to replace the sensor.
91 civic 4dr
b16a
14.8@94
Old 04-08-2004, 02:29 AM
Re: problem with b16a swap, engine code
nailed it man, iacv filter
Thanks
91 acura intregra with b16a swap black91acura Integra 1 01-01-2007 11:05 PM
timing problems with 1.6l engine swap plz help naz2006 How-To's and Walk-Through's 3 04-08-2006 12:20 AM
new b16a swap engine running like poop civicHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 11 08-28-2004 09:14 PM
Problems after b16a swap rosman4u Engineering/ Technical 27 05-15-2003 05:11 PM
startup problems with b16a swap rosman4u '88 - '91 Civic | CRX | Wagon | Shuttlee 9 05-12-2003 09:39 PM
