Old 04-07-2004, 10:16 AM
randy8916 randy8916 is offline
Send a message via AIM to randy8916
stall...wont turn ova
i started my 2000 eclipse this morning and was letting it warm up. it ran for like a minute maybe 2 and then it just stalled instantly no hesttation or anything just a stall.......i go to start it back up and it makes the noise any car does b4 it starts and just keeps making that noise......it just doesnt start....anybody know what it could be.....fuel filter or pump maybe???? any help is appreciated thanx guys
Old 04-15-2004, 11:27 PM
djay1991 djay1991 is offline
Most likely you have a dead fuel pump. Check to see if you have any fuel pressure. Most cars nowdays have a place where you can do this. It will look similar to the top of a tire valve stem only about 3x the size. make sure it is connected to the fuel rail and not the AC. If you don't have one disconnect a fuel and see if you are getting any fuel. also listen for a humm cumming from your gas tank. If you don't get any fuel or it has only weak pressure your fuel pump is bad.
Car stalling when turning and braking (Holden VX Commodore Lumina) Asmodaes Commodore/VS/VT/VX 4 11-19-2010 11:00 PM
Help just in stalled shocks and electronic leveling compressor wont turn on H22_DB2 Park Avenue 4 10-14-2009 07:10 AM
car stalls when turning left persondude44 Engineering/ Technical 5 04-16-2009 08:18 AM
wont turn over after it stalls FrodoGT '88 - '91 Civic | CRX | Wagon | Shuttlee 10 07-06-2005 11:18 PM
