Old 04-07-2004, 09:59 AM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
RE: Fuel Pump or cat. converter???
I still have the spitting and sputtering problem in my ('89 civic DX hatchback 1.5L, 5 speed) and I was wondering if it were the fuel pump or cat. converter. It idles really weird. When I accelerate, it's almost as if my car had VTEC, because it's really mopey until I hit about 4200 RPM, then you can feel it kick in, and it was hard to start. I've replaced the plugs, plug wires, O2 sensor, fuel filter, air filter, and checked things like oil and transmission oil. Does anyone know what it could be?
Old 04-07-2004, 10:00 AM
Re: RE: Fuel Pump or cat. converter???
...oh yeah, it's a real bitch on gas too!
Old 04-07-2004, 10:49 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
when you get around 1/4th tank of gas when you go around a corner does it sputter then? you can replace the strainer without doing the fuel pump (suggested) cause the fuel pump cost like 100+ and the strainer is 15 bucks. my engine started doing that and i just replaced it cause i was tired of putting money into it.
Old 04-07-2004, 11:32 AM
JimCRX's Avatar
JimCRX JimCRX is offline
sounds like yer getting too much gas. Before I go further how many miles are on the car and give the engine specs
Old 04-07-2004, 07:55 PM
The car has 229,000 KM (144,000 Miles) on it. It's the 1.5L SOHC 16V engine with a 5 speed manual. The fuel strainer? Is that the sock filter that goes over the fuel pump? And if I were getting too much fuel, how could I solve this? Maybe more air via custom 3" cold air intake?
Thanks guys for the responses.
Old 04-08-2004, 01:08 AM
lilol89crx lilol89crx is offline
check cam timing.......sounds like its retarded a bit.
Old 04-08-2004, 11:19 AM
JimCRX's Avatar
Yeah, check the timing if you can first. If it's good, run some fuel cleaner. BTW, is your cat. converter hollowed out or aftermarket? That could be the problems if it is. If not then, has you headgasket even blown before or have you ever burn antifreeze up? Cause sometimes anti-freeze clogs the cat. converter, like mine so I had to hollow it out.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 10:36 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
