Interior Lights Won't Turn Off
Hi. I'm new here and would like as much help as I can get. My 1995 Chevy Blazer's interior lights will not go off. I have tried slamming all the doors shut (including the rear windows) as well as playing around with the buttons for each of the 4 doors and for the trunk. I need help. Any ideas?
Thanks, Oz |
Re: Interior Lights Won't Turn Off
Does your interior buzzer keep sounding too? Have you manually pushed the buttons in that turn the light off, have you turned the dial on the dash down one click to ensure its not in the "on" position.
Yes, I did all of these. The buzzer does not sound but the lights stay on. My current solution has been to pull the fuse, but I would rather not do this long term
Oz |
Hope this will help,
Had the same problem with My Blazer, Found that the switch for the back window closing is not designed very well, After time the gap between the pressure switchin and the glass will increase. eventually it will increase to a point where it will not turn off the light. I used on one of those felt pads you use under furnature for not scratching your floors and it made up the diff nicely. Now it goes off NP Mack |
I have the same problem with my 96 I have checked all the switches and still have the problem at a loss.
If it won't fit get a bigger hammer |
