Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 04-06-2004, 10:41 PM
elevenup3down elevenup3down is offline
Send a message via Yahoo to elevenup3down
Question Crankshaft Position Sensor Nissan Pickup
I just replaced the Clutch in my 97 Nissan pickup. When i started the engine after the replacement the Check Engine Light came on. When i read the code Its the CPS. When i looked under the truck i found a sensor unattached however i do not remeber taking it out and have no clue where it should go. Can anyone clue me in?
Old 05-17-2004, 05:13 PM
jeff mcnemar jeff mcnemar is offline
Re: Crankshaft Position Sensor Nissan Pickup
my truck has the same problem, has anyone told you where to plug the sensor in? I can't seem to find where to plug it in
Old 05-17-2004, 10:43 PM
shortysdrop's Avatar
shortysdrop shortysdrop is offline
I assume you mean the crank angle sensor? Its built into the distributor. The trouble code is 11. If you use the self diagnosis off the ecu, it will show 1 red flash and 1 green flash. From what I understand if the sensor is bad the whole distributor has to be replaced.
Old 01-11-2006, 03:19 PM
billtech billtech is offline
Thumbs up Re: Re: Crankshaft Position Sensor Nissan Pickup
*** Finally FOUND The Crank Position Sensor! On TOP Of Engine Block, below the cyl head, An Inch Forward Of The Bell Housing, Slightly Left Of Center; Can See Only A 6mm Bolt Head From Left Side of vehicle (in my case: a customers 1998 Nissan Frontier 4x4 pickup, 4cyl) Under Hood That Covers The Sensor; Remove This With A 1/4" Flex Socket And Extension; NO Room For 3/8" Sockets In There! Access Blocked By EGR Pipe, Cyl Head, And Firewall. Really Stupid Place. Then After Removing Cover, Can Get Right Hand In If Not Wearing Gloves, Wiggle Slightly And Lifts Up, And Is Plastic With A Tab To The Left Where That 6mm Bolt Goes Through Cover And Sensor. CANNOT SEE Sensor Even After Removed, Since Harness Is Anchored From Other Side And Is Tight. MUST Lift Trans ALL The Way Up TO GET THIS ACCESS.!
and btw, the sensor mentioned above in the DIST is the CAMSHAFT position sensor.
Important thing to know is: the CRANKSHAFT position sensor MUST be removed before the trans is unbolted at the bell housing, or it, the CPS, will very likely be damaged.
