Old 04-06-2004, 08:35 PM
Customdubs Customdubs is offline
HUMMER H2 LAMBO doors
Hey guys,
I have an idea
(1) The first was I wanted to change the doors on my H2 and make the lamborghini door.. THAT WOULD LOOK HOT WOULDNT IT...LOL I am not sure how t do the conversion but if any one would like to help me on this project i am welcoming you now.. I now it would look hot if i could do it ... I ahve an old hummer that is chopped so we can work from that
Thanx guys
TELL ME what u think
Old 04-06-2004, 08:37 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Re: HUMMER H2 LAMBO doors
wow...good trick, where is gafotes?
MAKE ART, NOT WAR
Old 04-06-2004, 09:06 PM
turbo type-r's Avatar
turbo type-r turbo type-r is offline
iv been askin how to do those doors since day one no one ever told me
lac - 80 % done baby!
Old 04-06-2004, 09:09 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Personally I think an H2 with scissor doors would be pretty ugly, but then again I think H2's are stupid, ugly, and a pussy version on the real Hummer.
You can make hinges out of brass rod and tubing. That is how I make hinges for my models. I suggest looking in the Tutorial Depository of the Car Modeling forum (this covers 1/24 plastic models normally)
-Mike
Old 04-06-2004, 09:16 PM
mike@af's Avatar
Re: Re: HUMMER H2 LAMBO doors
You do have to figure out somethings for yourself young grasshopper. There wont always be someone there to help you through life, try to figure it out, its not that hard.
-Mike
Old 04-06-2004, 09:30 PM
ill try on my di cast cts
Old 04-06-2004, 09:31 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
I think the tubing is probably your best bet. Try to copy the hinges that you will find on a few cars with butterfly doors. Usually for butterfly doors you would have two contact points but with an H2 you'll only be able to use one I think so you're gonna have to make it very solid.
Butterfly are the kind you're actually talking about since a Hummer cannot even have Lambo doors (http://www.statikdesign.com/scratchb...ody/doors.html). I plan on working on some in the next few weeks so i'll make sure to post.
Old 04-06-2004, 09:41 PM
so what u are saying is that i need to copy the frame of a butterfly door and then made the mold out of tubing.. do u thin i will have to weld i amd 17 so..could i use jb weld will that work....i am kind of lost in the explanation srry...
Old 04-06-2004, 09:50 PM
Old 04-06-2004, 09:57 PM
Old 04-07-2004, 10:22 AM
mike@af's Avatar
Why did you post the same thing three times almost 10minutes apart?
Dont copy the frame. What he is saying is Scissor/Lambo doors are not possible on an H2. You will have to make butterfly operating doors, this does not mean make the door it self, make the door open butterfly style; Thus fabricating a butterfly hinge.
I am 15 I weld but you dont have to weld brass. Welding brass is not done easily, thats why it is soldered. Soldering is similar to welding except it is done at a much lower temperature.
Just fabricate the buttergly hinges, and glue them in place with some epoxy or JBweld (AKA Welding in a tube )
-Mike
Old 04-08-2004, 05:25 AM
PETET's Avatar
PETET PETET is offline
ITS INNOVATIVE dude..
get out more.
[PROJEKTZ]
Old 04-08-2004, 08:46 AM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
well try cutting off the doors, then create hinge. i made a 1/43rd honda with lambos and i cut doors off then thru the dash took 2 metal rods and glued them ot the doors and molded around the dash. then you stickt he doors with rods into the dash, to open pull out and push up. i would have made diffrent style but room is limeted in a 1/43rd car. for a bigger truck, try a thicker rod then paper clips but not to larger, has to bend, and creat a hinge to push out and up
Old 05-05-2004, 08:10 PM
Naseer23's Avatar
Naseer23 Naseer23 is offline
Send a message via MSN to Naseer23
Is there someway that u could order the hinge from someone. Or can somebody give some steps about how to do this
Old 05-05-2004, 08:40 PM
mike@af's Avatar
Is there anyway you could read FAQ's, Search, and maybe figure out stuff for your self?
This is one of my pet peeves. People that dont search and just want answers handed to them.
Another pet peeve resurecting threads.
-Mike
