Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 04-06-2004, 07:31 PM
IsuzuBrad IsuzuBrad is offline
P1441 error code help?!
Does anyone know what this error code means. The books say something about a EVAP purge system. But i don't know where to start with diagnosising the problem.
Any help you guys can give me, would be greatly appreciated!!!
Thanks in advance,
Brad
Old 04-06-2004, 10:06 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: P1441 error code help?!
your purge valve is stuck open
Old 04-07-2004, 04:17 PM
Thanks for the help 2Eye. Now where would a newbie like myself locate that purge valve on my trooper?? I am assuming i need to replace the purge valve with a new one?? or is it something that i can clean and put back on.
THanks for the help and patience with my newbie questions!!!
Brad
Old 04-07-2004, 08:53 PM
year and engine size?
Old 04-08-2004, 05:12 PM
its a 1999 with a 3.5L.
Thanks, 2 eye
Brad
Old 04-11-2004, 11:39 AM
rodeo02 rodeo02 is offline
Brad, check your gas cap as well. If you ever smell gasoline fumes around the fuel filler area, the check valve in your cap is probably bad. Your tank has to maintain positive pressure for the evap system to work. If the pressure bleeds down, you will get evap system codes. It's only around $3 for a new gas cap.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
