Old 04-06-2004, 07:31 PM
cgr351 cgr351 is offline
98 accord 17's what tire size should i use
I have 98 accord ex 4 cyl I have 17 rims to put on but what tire size should i use and i also want to lower a bit to close wheel gap but not too much.Are coilovers a good thing and how bad will it affect alignment,Any recomendations would be helpful
Old 04-06-2004, 08:22 PM
mwkirchner's Avatar
mwkirchner mwkirchner is offline
I just put some 17's on my 98 Accord. The tires are P215/50R17's. They work well and keep the speedometer true.
Here is a pic with the new wheels:
As far as lowering it ... I am gonna do that too. I am looking into springs only. The ones I am looking at will drop the car 1 3/4" in the front and 1 1/2" in the rear.
Here is a picture of the springs I am speaking of:
Old 04-06-2004, 08:47 PM
Thanks what color is that mine is black currant.
Old 04-06-2004, 09:00 PM
mwkirchner's Avatar
NH-592P Flamenco Black
Old 04-07-2004, 01:13 PM
blacknight's Avatar
blacknight blacknight is offline
The correct size should be 215/45/17 or 225/40/17 It's ok to go with 215/50/17 you'll just have a little more meat on your tires. But if you go with that size, you will have to drop your car around 2 inches cause your car will be pretty high. Look at the pic in my sig. I dropped my car 1 1/2 in in teh front and 1 1/2 in the rear
Good luck
what's that red button on your steering wheel.......OOOHHH MMMYYY GODDDD :22yikes:
Old 04-07-2004, 05:06 PM
mwkirchner's Avatar
I overlooked the fact that the car was a 4 cyl ... my bad. I went to TireRack to find the information out for you. I went back again today and here are the results. The correct size should have been 205/50R17. As you can see by the enclosed pictures ... I ran the check for a coupe and sedan since you did not mention which you had. Both call for the same size though.
Old 04-07-2004, 06:52 PM
blacknight thanks for the info.Your car looks nice but how did you lower it and did you have any trouble with the line up?
