Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 04-06-2004, 07:43 PM
zdude zdude is offline
Send a message via Yahoo to zdude
still not starting
you all know my problem, not starting. i replaced the ign. coil, plugs, wires, dis. cap, and rotor.
the rotor spins, the starter spins, the fan spins. everything spins and seems to work right but the engine doesnt crank over. i tried checking the spark, but still am sort of unsure of the correct way of doing it. am i sposed to touch the tip of the plug to a ground and try to turn it over, or the thread to the ground.
btw, i still havent decided on whether im keeping the car or not, i guess im still throwin ideas around. im going to stick it out a little bit and see how long i can get it to run this time.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
89 240sx (sold then died)
85 735i (Died)
95 Corolla (Damn Deer)
94 Renault Espace (gave away lol)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 04-06-2004, 08:09 PM
G_@_SpeedAlliance G_@_SpeedAlliance is offline
Send a message via AIM to G_@_SpeedAlliance Send a message via MSN to G_@_SpeedAlliance Send a message via Yahoo to G_@_SpeedAlliance
Checking Spark
Ok here's an easy, (fairly) safe, two-person method for checking spark:
Pull one of your spark plug leads off the plug, and out of the head.
Stick an INSULATED screw driver into the end of the wire (make sure it fits without effing up the tip of the plug wire!!)
Hold the screw-driver by the insulated handle (unless you enjoy electrical current running thru your arm, etc.)
Hold the screw driver very close (but not touching!!) a bare, conductive metal surface. I.E. valve cover, strut bar, hose bracket, etc. The surface must be clean.
Have your buddy crank the engine; look at the small gap between the screwdriver and the metal surface you're using for a ground. You should see a small spark. This is best done out of direct sun light (so you can see the spark if it's there)
That's it, you're done, looks difficult, is actually easy.
(Perform this operation at your own risk. Warren G takes no responsibility if you screwed this up, and set yourself on fire, etc.)
Old 04-06-2004, 08:58 PM
Re: still not starting
thanks for the input, but it still doesnt have spark. i just replaced the ignition coil so its not that, i dont think its the distributer cuz the rotor spins. could it be the ignition module?? im thinking the ign. module is a little black boxy lookin thing bolted onto the ign. coil bracket. am i right?? cuz my friend had his car do the same thing, crank and not start, and it turned out to be his ign. module
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 04-06-2004, 10:13 PM
TheLogikal1's Avatar
TheLogikal1 TheLogikal1 is offline
Send a message via AIM to TheLogikal1
try talking to your car. sometimes i try to say sexy things to my s14 when its giving me a hard time. then i start caressing the steering wheel. once it turns over i slap the center console and call it a slut and a whore.
1998.5 audi a4 2.8l
5-speed quattro
1994 lexus sc300 (dead)
tein cs
kenwood flip out 7'' screen
1995 Nissan 240sx 5 speed (dead)
GP Sports Spec-D exhaust
Custom Carbon Fiber Intake
17'' ricer wheels in Kumhos
hahaha stole this pose off of koguchi...my shirt makes me look fat...ahaha
Old 04-06-2004, 11:03 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
humm...if your STILL not getting spark...it could be your computer...it controls everything..the ecm..or something like that...it costs like 80$ tho..mine did
Old 04-07-2004, 02:23 AM
stealthj's Avatar
stealthj stealthj is offline
Send a message via AIM to stealthj
do a compression test?
BANNED
Old 04-07-2004, 02:35 AM
PureSXyness PureSXyness is offline
Re: Re: still not starting
don't forget to caress the shifter, you know, give it a good rub
1996 Nissan 240SX
-Injen Short Ram
-Short Shifter
-Magnaflow 2.5 in Catback Exhaust
i swear, i'm working on getting mods
Old 04-07-2004, 11:48 AM
vsiev vsiev is offline
Send a message via AIM to vsiev
did you installed the distributor correctly? did you take out the whole distributor out( has gears at the end of it) and did you put it back correctly? If you don't, it won't start period cause of miss firing. Had to turn the dist over and over again until i had it to the right spot. Also change out that battery or try jump starting it first.
Hiya...
Need a FSM? Hit me up I'll send it to ya for FREE!
I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM
Sorry no 89-90 yet....
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Apexi Dual N1 Exhaust
Silvia Front End Conversion
Digital Climate Control
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 04-07-2004, 03:37 PM
yeah, new battery too, i only did the distributer cap, not the whole thing, and i try jump starting it all the time. no spark, im thinking it could be the ignition module, but i dont wanna be stupid and buy a new one w/out knowing what is actually wrong first. 120$ for a new module... im also thinking i could have gotten the wrong ignition coil cuz i just went to a place downtown, and talked to them about what could be wrong, and they looked up the ign, coil and said there is two. i bought the one i have now at napa, and they rip you off. i have free towing up to 50 miles so maybe ill just tow it to a shop so they can figure it out. im sick of playin with it. i just want to get is started, and next time it breaks down, im parting it out, then selling whatever is left as one piece, maybe someone will bite with the intention of rebuilding and redoing everything on the car.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 04-07-2004, 04:30 PM
kingcarm kingcarm is offline
Dude stop dicking around with your car and just bring it to your local Nissan dealer and let them fix it.
Carm
My 1991 240SX SE
Old 04-07-2004, 05:16 PM
if you want to sell parts from it let me know, i pretty much need the interior. But hey good luck i know you are frustrated and tired of it. Trying to get this hicas smogged and registered is a pain in the ass....took it to get it diagnosed. Hopefully we can solve the problem asap and get it to pass smog.
Hiya...
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 04-07-2004, 06:52 PM
good luck on the smog... I FIXED IT !!!!!!!!! all it was was some stupid wire that the kid before me spliced into the ign. coil harness, there was nothing on the other end of it though, so it was touching the chassis, making a ground. i cut that wire, and waaalaa, car starts just fine... like i said before though, if i have to spend another penny on fixing this car, im going to part it out, not yet though.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 04-07-2004, 07:10 PM
Omfg!!!
Bwhahahahahahahahahahahahahahaahahahaah!!!!!!!!!!!
that's fucking funny!!
Well glad you got it figured out.
I had a feeling it was something simple.
Old 04-07-2004, 08:37 PM
yeah it is pretty damn funny if you think about it, but the shitty part is it held me back for a month and a half. im just so happy i got it fixed for the time being.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
