Old 04-06-2004, 04:53 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
barometric pressure sensor...pro help need!!!
hi i did the 6 bolt swap into my 95 gs-tlooking from
http://www.magnusmotorsports.com/1g2g.asp .
now my CEL is on and i was wandering should i put that potentiometer on wire #85 so the ECU see less barometric pressure.how does would this affect the perfotmance of the engine.they say u should see performance increase,but i dont want to lean the car too much and f..k it up.do i need bigger ingectors.please help.thanks
Old 04-07-2004, 02:32 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: barometric pressure sensor...pro help need!!!
In order to avoid the Random Misfire CEL and limp mode, you need to make the ECU think you are at about 6000 feet altitude. Thats a LOT It will require you to add about 30% back in with an AFC or similar to compensate, or you will be in very sad shape. If the car is not going into limp mode, you need to pull that code and make sure it the RM code, and not something else. 95% of the time though you will get the RM CEL problem with a 6 bolt swap, and this is why I dont recomend a swap to someone that doesnt have a AFC and datalogger, or even better, DSMlink....
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-07-2004, 02:33 AM
AF - Advisor
And by the way, the Baro signal should never be changed to try to improve perdormance. Just trust me on that.
Kevin Jewer
Old 04-07-2004, 03:42 PM
dupeto_e's Avatar
thanks kevin.i'm goin to check whats AFC and how much it coast. and that DSMlink too...
i think i know what u are talking about.i,m goin to read some staff ,see what i can do.for now i,m not drivin tha car at all and woudn't bother the barometric sh.t.thanks alot...
later
Old 04-07-2004, 04:05 PM
dupeto_e's Avatar
so what about S-AFC ll from apexi for 290$?is it a deal?
Old 04-08-2004, 04:26 AM
AF - Advisor
Thats the one I was refering to. 290 is about the going rate for a new one. I used it for years, and with my swap in the beginning. I eventually upgraded to dSMlink though, which has a much nicer solution to the RM CEL issue (doesnt lie to the ECU about altitude).
If you have a 95 I STRONGLY suggest DSMlink for anyone with a swap. A palm/logger, chip, and AFC will cost the same or more than DSMlink and a 50-100 dollar laptop. If you have to buy a EPROM ECU for your non-eprom equiped car, then you might have an argument. But I still feel its well worth the extra 200-250 for the ECU to run DSMlink, especially with a 6 bolt swap.
Kevin Jewer
Old 04-08-2004, 07:27 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Um....what's limp mode??
Old 04-09-2004, 01:55 AM
AF - Advisor
When the ECU sees a random msifire it will put the car into a low power "limp mode." Essentially it leaves you enough power to drive around and get home but thats about it. After resetting the code, and restarting the car, it will go back to normal.
Kevin Jewer
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
