Old 04-06-2004, 04:36 PM
fad1ng san1ty fad1ng san1ty is offline
Send a message via AIM to fad1ng san1ty
Question Teg head on Civic block
whats the deal with putting integra engine heads on civic blocks? like, would that be easier than a swap? is there anybody who done it already? any pros/cons for it? somebody fill me in.. i saw this issue in the s2000 issue of honda tuning, in some guy's letter. thanks to whoever can help!! peace.
Old 04-06-2004, 05:55 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Teg head on Civic block
You can't stick an Integra head on a D-series block. And I don't know why you would want to replace a B16 head with a B18C head. The B16 head flows much better than the B18C head.
Empty Pockets Racing Member #1
Old 04-06-2004, 06:01 PM
boosted331 boosted331 is offline
Re: Re: Teg head on Civic block
The flow charts from B16's and GSR's i've seen are nearly identical, and they flow withing 3 or 4 CFM's of each other when fully ported. In fact, you should make a bit more power with a GSR head because it increases compression a touch.
Old 04-06-2004, 06:08 PM
GScivic7's Avatar
3-4 cfm? Is there any way I can take a look at that flow chart?
Old 04-06-2004, 07:11 PM
dude.. thanks!!
Old 04-07-2004, 03:40 AM
oi_boy oi_boy is offline
thats the plan for me and i KNOW it works. im going to put an integra type r head on a stock civic b18c bottom end. that engine itself will put out close to or around 300 hp.
Old 04-07-2004, 05:18 AM
GScivic7's Avatar
yah, only if the Civic's came with a B18C...
Old 04-07-2004, 08:43 AM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
They probably do when you dont know what your talking about...just a theory though...
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 04-07-2004, 12:55 PM
ive seen my plan work. check out the new issue of hot tuning and imports. this guy with a 90's (one of them...haha) civic hatch. put a fully ported and polished integra type r head on a b18c bottom. a b18 could fit into any civic with a bit of work.
Old 04-07-2004, 12:58 PM
GScivic7's Avatar
Okay, we all on this board know that B18's fit into civics, and with relatively no work at all. You said you are going to stick an ITR head on a STOCK CIVIC B18C bottom. FYI, no Civic ever came from the factory with a B18C motor.
Old 04-07-2004, 01:38 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Please, PLEASE attempt this and post pictures of the whole process, dynocharts, etc.. then the look of absolute stupidity on your face when you figure out that you're a fuckin retard. I'm sure it will look something like this:
Old 04-07-2004, 01:45 PM
Ricochet's Avatar
Banned
Re: Re: Re: Teg head on Civic block
Let me explain some things to you noob. A B18C1 is an Integra (not Civic) GS-R engine. A B18C5 is an Integra (not Civic) Type R engine. A Type R head on a GS-R block is a waste of money. You'll go from 170hp to about 185hp, for probably $1000 in labor and $1000 for the Type R head alone. Oh, and you'll need an ECU also ($200-$400). Oh yeah and high compression pistons to take advantage of the higher-flowing head ($900). You really think a stock, all-Honda motor application will push 300hp? That's how much a Subaru STi makes and it's boosted..
Old 04-07-2004, 03:03 PM
That's for a fully ported B16 head vs. fully ported GSR head. The results of comparing stock heads show the same discrepancies. ITR heads stock flow a bit better than B16's or GSR's because theyre lightly sanded from the factory, but when ported to the max all the vtec heads flow very similarly.
Old 04-07-2004, 03:14 PM
GScivic7's Avatar
wow...never realized they were really that close...thanks meng
Old 04-07-2004, 03:28 PM
Ricochet's Avatar
Banned
I've heard the B16B head flows better than all stock B-series engines. You wouldn't happen to have a chart with those numbers would you?
