Old 04-06-2004, 05:12 AM
maverick27 maverick27 is offline
Send a message via AIM to maverick27
Where Did the Oil in My GS-t GO?!?!
hey guys. the other day i went in for an oil chance and they told me i had little to no oil in the car. they checked around and couldnt find any trace of a leak. now i do find to have some oil where the spark plug wires connect (under the mitsubishi cover on the engine that everyone takes off cuz of heat) where is the oil leak coming from and i was thinking might it be cuz i do a lot of hard highway driving and dont really leave my turbo much chance to cool down??? HELP
Old 04-06-2004, 11:12 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: Where Did the Oil in My GS-t GO?!?!
i am not much of an expert but i did have an oil leak once. it turned out to be a bad gasket.
Old 04-06-2004, 12:19 PM
joemathews's Avatar
joemathews joemathews is offline
Sounds like a valve cover gasket leak if there is oil in your plugs. But a leak like that alone shouldn't make you lose that much oil...
1996 Eagle Talon
Old 04-06-2004, 02:10 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
how often u put oil in your car.for these cars is normal to burn oil.when was the last time u changed oil?
Old 04-06-2004, 02:49 PM
i think for our eclipse, it is recommanded every 3000 miles.
Old 04-06-2004, 04:36 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
the turbo will burn oil, but not THAT much. I've heard many many stories about dealerships only putting in 1 qt by accident and the poor person driving around for 3000 miles before even checking it. So that could have happened. You should check your oil about once a week from now on just as a heads up. As far as the leak goes, It could be a gasket, or a bad seal on your cap maybe? Mine was leaking like a stuck pig from the crankcase, but I doubt very highly you have anything like my leak. Hopefully your mechanic can figure out where it is if there is one, and they'll fill you back up. just keep an eye on the oil level and look around for a leak after drivin her hard. also, you may wnat to invest in a turbo timer if you don't have the time/desire to wait for the turbo to cool. it's only like 100 bucks, and would probably be in your interests. Good luck!
V8's are like tampons, every pussy needs one!
Old 04-06-2004, 04:50 PM
FDTT FDTT is offline
It is possibel that you have some very bad valve stem seals. This could cause you to burn off quite a bit of oil. Leave it for a month and you could be down a liter ot 2 easy.
Had a honda like that, thing went through so much oil. Hated that thing.
O well, just make sure to check your oil regularly, best thing to do is check it whenever you fill up on gas.
Dont drive faster than your angels can fly
Old 04-06-2004, 05:12 PM
awesome ill look into changing the valve cover and just take it to the mechanic. appreciate it guys
Old 04-07-2004, 04:26 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
make sure that the oil filter is on tight too.
Old 04-12-2004, 05:58 PM
srm2000mac srm2000mac is offline
Kind of off topic
Im not to sure about the oil but, something kind of off topic, you might really want to invest in a turbo timer like Import2nr99 said. If you dont like to wait a minute or so to let it cool down you can wrek your turbo. What happens is the oil cools your turbo down from spinning so fast. If you just shut off your car without letting it cool down the oil flow to the turbo stops. The turbo is hot enough that when the same oil sits in it it starts to absorbe the heat and your oil littearly turns into powder. That powder in there doesn't let fresh oil get to where it needs to go the next time you start your car and kills your turbo. It won't happen the very first time you don't let your turbo cool down but if you keep doing it the right conditions will fry it.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
