| Let's get Technical! Discussion for hardcore in-depth motor heads! |
i just completed installing a type r intake manifold on my 2nd gen b16a, when i went to start it up it ran pretty well for about two minutes then it started to surge raisng and dropping between 1,000 and 2,500 rpms, could someone tell me what the hell is going on??? i tested the whole thing for leaks and that was not the problem. one thing i might add is that my friend took off the throttle positioning sensor when cleaning my throttle body, dont know if that could be it but thought i would add that.
You might wanna check your IAC valve. I currently have this problem on my LS VTEC. IAC if you don't know is an Idle Air Control Valve, its located on your intake manifold on the back of it. Have you read what engine codes its throwing out. Check it out but most likely its the IAC valve.
Re: idle problem please help!
also if you cleaned your throttle body out..you might need to adjust your throttle body a little bit that is very common on motors like the 3sgte and 5sfe ...there will be an adjuster screw on the TB. also depending on what he used to clean it, you might have foiled a plug or 2.. so to be safe pull your plugs and check them out. But ill back ALMX up on his theory as well for that is a possable scenario
i replaced my IAC valve because my original would not fit the bolt pattern on the new manifold, i think its because of my tps, i didnt reinstall it correctly according to the voltage it was putting out.
im not an expert but are you sure that manifold is supposed to go on your engine...sounds like a mismatch
Re: Re: idle problem please help!
From the foothills to the bay, it shall ring, as we sing, It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail! |
ya it just takes slight modification to the manifold bracket that holds the manifold in place to the block.
