Old 04-05-2004, 10:00 PM
nrk_rider nrk_rider is offline
Cool build your own custom tube buggy scale model for cheap to none!!tutorial!!
ok so this might take a while and the spelling might not be good and i dont have a digi cam so wish me luck.
Ok so first off lets say your an offroad person. you want a custom tube buggy but WHERE THE HECK ARE YOU GONNA GET IT! heres my tutorial on how to do it
step1:go to a hobby store like michaels or somewhere.
step2: buy some sucker sticks (round white ones)
step 3: make your frame rails from 2 of the sticks glued together. some cutting may be required. depends how long you want it. 1 stick for a super small crawler. 1 and 1/2 (what i made mine out of) for reasonable buggy style.
step4: first line the fram rails you glued together up but a little far apart.
step5: take 2 sticks and glue them on each end (one at the top of the rails and one at the bottom) some cutting if you dont like the way they stick out.
step6:where the back bumper (the stick that holds the frame rails together) cut some sticks down to make a start ( liek this \ ) on each side of the bumper that holds the frame rails together THEN (forgot this earlier) put some stregnth in the frame by cutting the sticks (one will hold it well) in the middle of the frame for strentgh.
step7: after making the strentgh bar in the middle of the frame and making the back slanted bars ( \ ) add some to the part (if ur using 1 and 1/2) add a straight up small bar too the part where the 1 stick connects to the half on each side.
step8: lay one full bar down from the back slant bars to the straight bar you just added.
step9: as you can see its coming together, cut some small sticks to support each side of the bars on the side you just connected (the back slant bar to the straight bar and the one on top) and connect both the side bars (straight bars, back bars and top bars) together.
step10:take two more sticks and make them slant to the front bumper or right behind the bumper, which ever is better for you.
step 10: (yeah its not over yet) take some hard material like styrene or bendable plastic and make a flat surface to place your seats engine steering wheel ETC. after you have it in glue it to the middle frame support bar and the tope and bottom bumpers if your styrene or plastic is that long. wait to dry then cut your hole in the surface (plastic or styrene) to place the engine(the tranny only goes in the hole not the whole engine) and it should stick "up" in a position where if water or mud where to get that high the engine would still run.
step11lace a battery or battery pack (scale model ofcourse) inder where the engine sticks up to glue it down hold it inplace and look cool.
step 12:undo glueing the engine in and the battery, thats just a test fit. if your engine does not fit adjust until it does.
step13: PAINT! pick your color,primer it,and lay down some paint.
step14:cut some suspension out of the sucker sticks, lay them side by said and make sure they are PERFECTLY the same size.
step15: find your tires, wheels, and use 2 sucker sticks for axles.
step 16: glue the suspension to the bottom plastic piece (the styrene or flexable plastic like i said earlier) make sure it stands straight up until it dries.repeat until all suspension is glued on.
step17: put your wheels on the sucker stick axle then glue the axle to the suspension. repeat for front, or back depends on which one you did first.
step18: enjoy your work! step back grab a beer and even make engine sounds if you want! mods please add this to the tutorial section!! ENJOY EVERYONE!!!
Old 04-05-2004, 10:10 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Re: build your own custom tube buggy scale model for cheap to none!!tutorial!!
pics would be great
Old 04-05-2004, 10:15 PM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
easier said than done....lol
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 04-05-2004, 10:20 PM
said i dont have a digi cam i might be able to if my cousin comes over wendsday. i have mine almost finished painted n all its easy too do once you get the concept just make a frame and then a body (like look at some real tube buggys they make them out of steel tubes not just buy them out of a book!) and im starting another one tommorow ( a pickup truck tube truggy)
Old 04-05-2004, 10:22 PM
supermod04's Avatar
Banned
i know you said no cam, but it is pointless without pics, it was hard to read, i did not understand 1 thing u said
Old 04-06-2004, 09:15 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
-Mike
Old 04-06-2004, 10:09 AM
labandabonnot's Avatar
labandabonnot labandabonnot is offline
Seems interesting, would be perfect with pics! I hope you'll manage to send us some of your work on the next few days!
Back to life soon...
Old 04-08-2004, 01:38 PM
Cool Re: Re: build your own custom tube buggy scale model for cheap to none!!tutorial!!
yes hopefully! but it depends im kinda busy and my cousin might not be able to come over because he got in trouble. but if he can i will take some pics !
Old 04-08-2004, 02:39 PM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
http://briansmodelcars.com/tutorials...D=13&CurPage=1
Old 04-08-2004, 02:55 PM
Howielong's Avatar
Howielong Howielong is offline
Send a message via AIM to Howielong Send a message via MSN to Howielong Send a message via Yahoo to Howielong
Originally Posted by SonyMobile
My god. Thank you. I want to build a cage now.
Old 04-08-2004, 05:33 PM
turbo type-r's Avatar
turbo type-r turbo type-r is offline
Originally Posted by GTmike400
beat me to it
lac - 80 % done baby!
Old 04-08-2004, 05:37 PM
i have on quik question does styrene bend easy and if it kan dos it brake easy
Old 04-08-2004, 05:42 PM
Howielong's Avatar
Solid styrene seems to want to break when trying to do a full 90 degree bend so a little heat helps it a long. But just a little! Hollow tubing seems to be more forgiving and all you need to do is over bend it a bit and it should hold its shape. If it doesn't again just give it a little heat with a candle or lighter and it will soften the plastic. When it hardens it's solid and ridged. Some trial and error here!!
From the site.
Old 04-08-2004, 10:32 PM
primesuspect407's Avatar
primesuspect407 primesuspect407 is offline
cant i just use old parts trees for a cage (i'm cheap)
large scale models for cheap Integra14 Car Modeling 2 10-03-2003 10:48 AM
Build your own P10 front kit p_r_i_m_e_r_a Cosmetics 73 12-17-2001 05:11 PM
