Old 04-05-2004, 11:31 AM
Mojoe Mojoe is offline
Reverse RPM Dip
After the engine is warm and I put it in reverse, the engine drops then picks back up. Car idles around 900rpm, put in reverse and tach bounces to near 0 then up alittle then back to near 0 then back to 900...all happens fairly quick. Car backs up fine, no unusual noises. Reverse lights work, replaced main relaya month ago. Car has done this ever since the first turn of the key on the 2 month old swap.
91CRX HF
B16A w/ S1 tranny
Old 04-05-2004, 12:44 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Reverse RPM Dip
so, does the engine actually go to 0 rpm or does the tach just go to 0 rpm? ur car wouldn't be running when you put it in reverse if it dropped to 0 rpm
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-05-2004, 02:49 PM
Re: Reverse RPM Dip
The tach drops alot and the idle drops alittle. The two codes I have are fuel injector (all injectors measure 2ohms, noid light lights up on all 4 of the connectors) and tps. I have always had the fuel injector code since day one. Didn't get tps til i tried to hookup vtec indicator light...i unwired the vtec light the same night I tried it. Couple other bugs like no horn(sometimes it kinda moans like a sick cow) and door bell is intermittant but I dont see where any of those bugs point to the reverse rpm/idle dip crap.
Old 04-06-2004, 11:13 AM
bambam89lx's Avatar
AF - Advisor
Re: Re: Reverse RPM Dip
Ur supposed to have 6 OHMS of resistance to all injectors!!!!!
Old 04-06-2004, 11:34 AM
Aeolus's Avatar
Aeolus Aeolus is offline
Send a message via AIM to Aeolus
[quote=Mojoe] The two codes I have are fuel injector (all injectors measure 2ohms, noid light lights up on all 4 of the connectors) and tps. [quote]
did you put the appropriate cover sheet on your TPS report?
sorry, all kidding aside, i have no idea.
D16A6: 105.7 whp - 95.7 lb/ft
15.4 @ 89 mph - 60' 2.20s - 0-60 7.0s
Old 04-06-2004, 07:42 PM
Re: Reverse RPM Dip
6 ?????? Helms manual says you should get between 1.5 - 2.5 and brand new RC's are only 2.5 - 3ohms...
Peak and Hold: http://www.rceng.com/prices.htm
Old 04-06-2004, 08:05 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
Re: Re: Re: Reverse RPM Dip
yeaaahhhh, didnt you get the memo?
As American As A Burrito!
USDM 4 life!
