View Poll Results: Have you ever needed to replace broken coil springs on Ford Escort or other Fords?
Yes 36 67.92%
No 17 32.08%
Voters: 53. You may not vote on this poll
Old 04-05-2004, 11:59 AM
emti95 emti95 is offline
broken rear spring
I have a '93 Escort LX that had both rear springs broken near the bottom at around 130k miles. I bought it with 119k miles on it so don't know the earlier history. I was told by the mechanic at the repair shop (Goodyear) that this is a common problem with Escorts. I had to have the springs replaced again at 170k miles when the upper strut support on the left side rotted out causing the spring to shear. It rubbed against the tire but did not puncture it.
A coworker just bought a '97 Mercury Mystique from an elderly woman. The car has only 17k miles on it and it too has a boken spring!!! Sounds like FOMOCO has a problem with rear coil springs. Anyone aware of TSB's or recalls on defective springs?? I know of a recall to install a shield to prevent tire puncture if the sprigs break.
Old 01-14-2005, 06:38 PM
panzees36 panzees36 is offline
Send a message via Yahoo to panzees36
Re: broken rear spring
I personally have never had to replace the springs on any of my Escorts yet.
Old 02-20-2005, 09:24 PM
ALMB~Nova ALMB~Nova is offline
I have replaced all 4 springs on my wagon and have done this on other escorts also hard to find in junkyards because there all broke too.
Old 07-22-2005, 08:23 AM
wileys wileys is offline
My `92 had both rear sprins broken at the top when I bought it. I just also replaced 2 broken front springs on my `94 Tempo ... it makes me curious about defective Ford springs too.
Old 07-22-2005, 08:57 AM
Bobbywolf Bobbywolf is offline
My 95 escort had a rear broken spring too, broke up near the top.
Old 11-30-2005, 11:44 AM
mmichel mmichel is offline
Just had to get the rear springs replaced on my mother In-Laws 99 SE. The car only has 30k miles. I have never had to replace springs because of rot before. I've replaced shocks and struts for normal wear, but never for spring rot. Sad quality.
Old 11-30-2005, 05:35 PM
Davescort97 Davescort97 is offline
Escort guy
97 has never had a broken spring. The struts replaced yes. But, no broken springs. 140,000 miles on it
Old 12-01-2005, 12:02 AM
Escorts4ever Escorts4ever is offline
I have two 95's, a tracer and a escort. Both rear springs on both cars are broken. 60k when they went.
Old 12-01-2005, 08:25 AM
Nocturnall Nocturnall is offline
Send a message via AIM to Nocturnall
Re: Re: broken rear spring
Just replaced both of my rear springs on my 94 EGT due to them being broken. I was checking out the springs after I took them out and they're tapered towards the bottom where they just so happened to be broken.
Old 06-20-2006, 04:45 PM
Zuggalo Zuggalo is offline
I also have a 93 escort lx. I got the car at about 130k and I had the springs break at about 155k. At first I blamed myself (I caught air off a railroad track incline) But in my reading I've learned that it is pretty common, so now I just blame age. My neon took the same jump and no harm was done.
Old 06-21-2006, 10:36 PM
I broke a rear spring some time ago, and then a front spring this year. These care are notorious for it.
Old 06-27-2006, 11:53 PM
Cruize Cruize is offline
I had to replace the rears to pass inspection. I probably had somewhere around 130 or 140k miles. They were broken at the bottom. I replaced struts at the same time; I needed new ones anyway. If the springs break again, I might just try cutting the broken sections off and drive with a slightly lowered back end.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 07-07-2006, 11:31 AM
quickywd01 quickywd01 is offline
97 lx wagon needed new springs. Maybe we overloaded it once by having four people in it and a hundred pounds in cargo. We never really noticed it that much but once new springs and shocks were in the back it was great.
Nissan, Subi, Yoter, Ford
Old 07-07-2006, 11:39 AM
12Ounce 12Ounce is offline
Slightly off subject ....
But does anyone know a source of slightly longer, or stiffer, springs so I can boost the rear of my '82 wagon a bit?
Old 11-01-2006, 01:55 AM
jamesmetairie jamesmetairie is offline
is the recall for 1999 models also? what,s the syptoms of a broken spring? i recently purchased a 1999 lx and it don,t feel too good at interstate speeds.
