Old 04-05-2004, 10:43 AM
sl85260 sl85260 is offline
daylight running lights
Can anyone tell me how to get at the factory running light bulbs to change them?
Thanks,
sl85260
Old 04-05-2004, 04:48 PM
buzzbee buzzbee is offline
Re: daylight running lights
can you tell us what year ????????
Old 04-07-2004, 11:34 AM
JD68 JD68 is offline
If its a sealed beam headlight then there are screws holding it in with a surround, pretty straight forward, if you have composite beams, then there are two hex posts directly above the lights on the same plane as the radiator remove either type and the assembly will come out forward and replace your bulbs
dont forget you might have to adjust them after you replace them.
Old 04-09-2004, 01:49 PM
2000 tahoe new style.
How do you get at the daylight running lights? It looks like you have to pull the entire grille. Any ideas?
Old 04-10-2004, 06:08 AM
Daver84 Daver84 is offline
Pull out the two pins that hold the headlight housing and remove it. There is a plastic spring clip at the back outside edge of the signal/daytime running light housing that has to be pushed in to remove the housing.
