Old 04-05-2004, 07:26 AM
Alonnzo007 Alonnzo007 is offline
Follow Up
There could be many things that can give you poor performance. Most important check your ignition system (cap/rotor, plugs, timing, plug wires) and then your fuel system (listen for injectors using a long screwdriver, check fuelpump and fuel pressure). It is true that your O2 sensor can give you problems but I believe the cpu should give you a code. Also you might want to check the EGR valve.
Old 04-05-2004, 05:49 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Follow Up
I am thinking you meant to hit the , but instead hit the
Old 04-05-2004, 06:00 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: Follow Up
yeah this belonged in the thread about the valve clearance, although I am pretty sure the guy caught it and got it where it belonged
LS1 RX-7 Zoom Zoom
