Go Back   Automotive Forums Car Chat > Ford > Commercial Trucks
Old 04-05-2004, 04:06 AM
AUTOHANDLER36 AUTOHANDLER36 is offline
Ford L8000 Diesel Help
Hi, I Have A 1987 Ford L8000 Diesel And When I Shut The Key Off The Engine Stays Running I Have Replaced The Ignition Switch And The Fuel Cutoff Solenoid But It Still Does The Same Thing Any Help Would Be Appreciated Thank You
Old 04-05-2004, 09:13 AM
ModMech's Avatar
ModMech ModMech is offline
Re: Ford L8000 Diesel Help
What engine? You could have anything from a Brazilian Ford, to a Big bore Cummins or Cat in that truck.
Old 12-07-2004, 11:09 PM
fordman1981 fordman1981 is offline
you could have a blown fuse or a frayed wire somewhere between the solenoid and the ign switch , or posibly your fuel injector pump could be leaking fuel past the shutoff valve what kind of injector pump do you have if its a older robert bosch with the solenoid having a external linkage to the pump your valve could be leaking
