Old 04-05-2004, 12:51 AM
DtB251
Guest
Posts: n/a
What's the proper way to paint or re-coat my intake?
Last edited by eckoman_pdx; 01-13-2009 at 10:51 PM. Reason: post was inappropriate
Old 04-05-2004, 01:24 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Cold Air Intake Help!!
scuff it, primer it, paint it
next time post it in the right section whatever that might be...
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-05-2004, 01:58 PM
DtB251
Guest
Posts: n/a
Re: Re: Cold Air Intake Help!!
scuff it?? don't get it please explain more if you could? i thank you for the reply though.
this would be the closest section to an intake question i believe..
Old 04-05-2004, 07:22 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Re: Cold Air Intake Help!!
Actually NO!. This is a JDM only section. Hence the subject title of it that you clicked to get in here to post. Try technical, or similar forum area.
By scuff, he means sand it out to give a more paint friendly surface. Then paint it up with primer, and then with whatever paint you plan to use. I'd go 2 coats of primer, and at least 3 coats of top-coat paint. Also make sure you are useing Hi-Temp paint that can withstand high heat temps.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
