Old 04-04-2004, 08:46 PM
titleist312 titleist312 is offline
Tranny Temp
I was recently driving my 04 ws6(comp g) fairly hard and noticed after heavy use of the tap shift my factory tranny temp gauge reached 221 but wouldnt go any higher. 1st off is 221 bad (never had a tranny temp gauge before) and is this as high as my factory gauge will go?
Old 04-04-2004, 08:51 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Tranny Temp
What does your manual say?
I know that I hate seeing the temp get anywhere over 190. If it went any higher then 250 I'd pull over.
Old 04-04-2004, 09:00 PM
Re: Tranny Temp
i guees i should read the manual and see if it says anything. Yeah 250 would be a good time to pull over 221 was scary enough. I now know why guys are running tranny coolers on these things but zzperformance says not to waste your time with one. As the broken trannys they have seen were not from heat problems but just simple broken HARD parts, so really how strong are these trannys?
Old 04-04-2004, 09:06 PM
Ripn12s's Avatar
Re: Tranny Temp
Well, Ive broke 2 or 3 so far
Old 04-04-2004, 09:13 PM
Re: Tranny Temp
OUCH! what about these guys at zzperformance? they sound knowledgeable, are they?
Old 04-04-2004, 09:20 PM
Ripn12s's Avatar
Re: Tranny Temp
Ya, there good.
I didnt believe in trans coolers until I moved to Texas.
ZZP/INTENSE are located in MI and OH. So they do NOT see the high temps that I see on a daily basis down here. One of their complaints about the coolers is busted hoses and bad connections. I run the MSP desert fox cooler that uses barbed fittings and aeroquip, I think thats what they are called, lines. I have had no leaks at all, not a single problem.
All of my trans failures where hard parts, non due to heat.
I've broke 2 differentials
1 input shaft
1 pump shaft
Old 04-04-2004, 10:57 PM
Re: Tranny Temp
ok thx. how much hp./trqe do you think you have that is causing your problems? am i gonna need to worry with enough hp to get me into low 14s/ high 13s?
Old 04-04-2004, 11:15 PM
rockford0384's Avatar
rockford0384 rockford0384 is offline
Re: Tranny Temp
i once hit 235 w/out a trans cooler going through mountains going into cali, but when i got back into AZ i got a trans cooler and ever since i have put it on i have not yet seen it go over 180. and I drove back from there in august (going back to michigan) and it stayed 165 on highwaywhen i got off it went like a hair under 180 (like at lights) get a trans cooler. original trans over 125,xxx miles
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver,
still trying to figure out how that happened
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 04-05-2004, 07:27 AM
Ripn12s's Avatar
Last time I had the car dynoed it was 291 fwhp cant remember the torque.
I had no trouble w/ the trans when I was running 13.8s
Installing tranny cooler, tranny temp gauge Moser97 Blazer 31 05-04-2006 01:55 PM
Running wire for tranny temp gauge feistranch Windstar 2 05-10-2005 11:47 AM
Tranny Temp gauge 2001 Tahoe LT wpendl1 Tahoe 0 11-26-2004 02:28 PM
Tranny Temp Guage? a_alyte Grand Cherokee | Grand Cherokee SRT8 1 10-30-2004 10:29 AM
tranny temp gauge. thunderbird muscle Mustang Talk 2 08-07-2004 01:42 PM
