Old 04-04-2004, 06:36 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Rear suspension bushings...??
Alright, I had a couple extra hours in class the other day so i decided to put on my rear struts and coilovers. The bolts holding the bottom of the strut to the control arm were of course seized so since i had new everything, I just cut it all out with a torch. The only problem is, now the bushings need to be replaced. Ive called around to numerous parts stores and no one sells replacement bushings for the rear lower control arm. I know some of you guys must have run into this before too, so whered you gets your bushings? Are their any online stores or anything? I dont have big bucks to spend at the dealership unless its absolutely necessary.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 04-04-2004, 07:34 PM
ButterMule ButterMule is offline
Send a message via AIM to ButterMule
i had the same problem your better off getting poly bushings, cheaper and easier to put in, go to: http://suspension.com/civic.htm i got mine within acouple days of ordering.
Old 04-05-2004, 07:22 AM
Jinx2004Riceboy Jinx2004Riceboy is offline
Send a message via MSN to Jinx2004Riceboy
Lightbulb Bushings
You can go to NOPI and get a complete bushing kit for like $150. It's a pain putting hte rear ones in though, you'll need a press.
Old 04-05-2004, 09:13 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Rear suspension bushings...??
if you dont wanna do that, just run to the junk yard and pick up some used lower control arms for cheap...saves the hassle of installing new bushings.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-06-2004, 02:58 AM
BullShifter's Avatar
Re: Re: Rear suspension bushings...??
www.hondaautomotiveparts.com
I agree, control arms are much easier than bushings to change even with the right tools.
Old 04-06-2004, 05:34 PM
cp___32 cp___32 is offline
I had that happen too....I went to my local ALTROM for the bushings that the shock bolt went through.....and I got poly bushings for the other two spots...they came in a kit....You have to get the sleeves pressed out where the old bushings were...If you look closely there is a metal cylinder inside the hole for the bushing....it's on the outside of the bushing when you buy new ones...you have to get that pressed out or the new bushings won't go in....If there's an ALTROM in your town....the're great for very inexpensive parts....(Canada I mean) goto www.altrom.ca if you'd like to see what they offer....but the only do DEBIT OR CREDIT CARD...NO CASH.....
CRX DX Rear Bushing replacement rusted '88 - '91 Civic | CRX | Wagon | Shuttlee 10 08-19-2009 11:08 PM
87-91 Camry Rear Suspension Parts F/S nohablaingles Classifieds 0 07-02-2009 10:22 AM
Question about rear suspension bushings - with pic 97GSTspyder Brakes and Suspension 0 11-27-2008 02:39 PM
92 Rear suspension bushings Acidbath Taurus | Taurus Wagon 0 04-19-2004 01:53 PM
