Old 04-04-2004, 06:29 PM
baller0657 baller0657 is offline
Send a message via AIM to baller0657
amplifier problem help PLZ
Hi i recently purchased the lanzar HTG224 600 watt 2 ch amp. After installing it the green power light came on and evertything appears hooked up fine but there is no improvement in sound. To check if the amp was adding any power i removed the fuse from the amp, and there was no difference. It is very weak sounding almost no bass, and when i adjust gain and bass on the amp it makes no difference in sound. Im looking for any advice you might have, did i get a bad amp or do you have ideas on what could be wrong?
Old 04-04-2004, 06:45 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: amplifier problem help PLZ
how did you hook it up?
is this powering speakers, subs, what?
It sounds like you just hooked the amp up to power and left your speakers hooked up to the headunit...
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-04-2004, 06:49 PM
im powering two subs, both are plugged into the amp. all the wiring appears fine, just not a damn watt bein added to my signal.
Old 04-04-2004, 06:53 PM
sr20de4evr's Avatar
how exactly is everything hooked up
rcas, power, ground, speaker wire, etc
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-04-2004, 07:14 PM
i dont get what you mean,
pwer to battery
ground to bolt near taillights
rcas to hu
remote to hu
speakers are wired 1 to each of the 2 channels
umm hope thats wut ya meant?
Old 04-04-2004, 07:34 PM
sr20de4evr's Avatar
yeah, I was just making sure it was wired up right
When everything is playing are the subs moving at all? Did you make sure to turn the sub output on the headunit on (if your headunit has that feature)?
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-04-2004, 07:49 PM
they move barely, i dun think mine has that sub output think, whats it look like?
Old 04-04-2004, 10:53 PM
slinker slinker is offline
I think hes saying it would be an option in the menu of the HU. Like, maybe an option to turn the sub output ON or OFF. I doubt there would actually be a specific button for it on the HU, you would probaly have to navigate thru the menu a little. Check the HU manual i suppose
Old 04-11-2004, 09:18 PM
thx alot guys...it was the rca's
1985 coupe deville problem help plz automag Deville 1 10-09-2004 11:35 PM
turn signal problem? help plz. turbo2nr Jetta/Vento/Bora 1 06-26-2004 03:29 PM
Engine problem Help plz MidwayAvenue Camaro Discussions 3 05-19-2004 01:33 PM
90 camry dash light problem help plz vsvaz Camry/Camry Hybrid/Vista 0 04-05-2004 04:53 AM
Law Problem... HELP PLZ! Robs '03 si '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 06-01-2003 08:34 PM
