Old 04-04-2004, 02:54 PM
chris1234 chris1234 is offline
Question 93 GT trans
Can't find filler plug on my 93 GT w/ 1.8- 5 speed.
Old 04-04-2004, 04:35 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: 93 GT trans
ok, its hard to explain, but, lets say your changing your oil, on the right of the vehicle, now go to the left, where the tranny is, and you'll be looking from the back of it, and right on top there, you should see a plug with a clip, bolt and wire, thats your speedocable, that is your fill point. there is no dipstick. your have to drain it from the drain plug on the bottom, and when you remove that plug on top, there will be gears on it, and you have to fill it up to a certain point on one of those gears, i belive its like 3/4 of the way up, but you can get a haynes manual to make sure. but if you remove the air intake tube, and look right underneathwhere it used to be, down from the top over the tranny, you can see the plug right there to with that same cord connected to it. its hard to find at first
