Help, my '92 Celica has just started to shake when I accelerate. It is fine in the lower speeds but between 40-65 mph when I step on the peddle the entire car starts to shake. The steering wheel doesn't shake at all, and when I let off the gas or am at cruising speeds the car is fine. Any ideas?
Re: car shakes during acceleration
check your carb settings for the throttle see if all thats good, cuz i had that problem with my 89 f-150 and a cable attachment to the carb was cracked, then check timing, but carburator would be my first check. if you cant fix it take it to napa, or autozone if theres one around
bad rear tire balance could cause that too, have someone follow you and have them see if your rear tires bounce at all, that was a problem with my friends car.. And would a 92 really have a carb on it?
1987 Mazda B2200
uh dude, the celica past like 83 was EFI. no carb
Stock your right there was no carb but a lot of people are getting engines from LCEngineering that are older engines to swap into their cars, but I highly dout someone did it to a 90's model..
1987 Mazda B2200
my bad didnt know what year they changed to efi.
yeha man check the wheels seen that problem before mabe have a look at the engine mounts
N*E*R*D Without a course |
Dude, had that same problem with my first celica. Mine was a broken motor mount. Easy fix.
JJJimmy |
Motor mounts is definately somthing to look for..
1987 Mazda B2200
rofl, check your allignment, duh.
motor mounts only has to do with your engine moving back and forth when accelerating and de-accelerating |
![]() 91 Celica GT-S www.cardomain.com/id/ole_school_celli |
