Old 04-04-2004, 10:51 AM
mwood mwood is offline
1995 f250 transmission stall
I have a 1995 f 250 auto that stalls when shifted into reverse and 1st gear. The transmission shop hooked up to the computer and it inticated that there was no problem, and thoughts. This does not happen everytime and sometimes the idel will drop way down, catch itself and not stall.
Old 04-04-2004, 10:01 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 1995 f250 transmission stall
Do you have an "OD cancel switch" on the end of the shift lever? If so, you have an electronic A/T, and the problem is most likely a bad idle air control solenoid (IAC), especially if it has trouble holding a steady idle at other times, or stalls.
They can be "cleaned", but that's a patch, and new ones are neither difficult to replace or expensive.
Old 04-04-2004, 11:34 PM
I will have to confirm the OD cancel switch, but the idle air control solenoid is a place to start thanks for the info
1995 Astro Transmission Slipping Dannoastro M Bodies 5 02-12-2011 01:07 PM
1995 f250 cab chassis rear axle JMB_272 F Series 1 09-30-2005 07:39 AM
1995 F250 Check engine light point_man8 F Series 2 02-03-2005 04:13 AM
1995 F250 integratool666 F Series 18 07-10-2004 11:38 AM
1985 F250 Diesel stalls after startup mikedrakesmith F Series 0 11-08-2003 11:37 PM
