Old 04-04-2004, 04:05 AM
2of9 2of9 is offline
Double-Clutching in GST/GSX?
Friend of mine said Double clutching in the Turbo DSMs arent good, bcuz its making the turbo work "TOO HARD" is he rite?? i thought double clutching was really good, while racing or showing off" For me, i think he doesnt kno what he's talkin about. i said if you did that regular driving, its not good...its not even good for the car, but in racing, i think its useful. What you guys think?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 04-04-2004, 04:23 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: Double-Clutching in GST/GSX?
....umm....i think double cluthing wouldnt be good in racing.....its used for semi trucks....
Old 04-04-2004, 04:48 AM
youngmanvr4 youngmanvr4 is offline
Yea...unless your racing to be the slowest person i wouldn't be double clutching in a race.
http://www.automotiveforums.com/vbul...d.php?t=194729
Maybe this will help you under stand what Double Clutching is.
Old 04-04-2004, 08:34 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Stop listening to fast and the furious.
Anyways... Why would double clutching be any different from pressing in the clutch, putting it into a lower gear, then reving it and then letting the clutch out.
Seems the same too me, just that your doing all of that in neutral in double clutching. Just seems like extra work.
For Sale 98 Eclipse GS, 5 spd
Old 04-04-2004, 01:07 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
i like double clutching when im slowing down to a stop light or, getting off the freeway. but, huu, thats about all its good for..
Old 04-04-2004, 01:52 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
HAHAHA watch fast and furious much? I've used doble clutching on military duece and a halfs and hemtt's. it is simply to keep the rpm's up between gears so that you don't bog out on the next gear. if you're shifting that slow in a race on a 4 cylinder sports car... you have other problems. I don't think you really grasp the concept of double shifting. and your friend needs an update too. Sorry man... no.. double clutching is the worst idea. they only say it in the movie cause the script writer looked up a bunch of driving terms and threw them in there to make the actors look even more retarded. Watch the movie again closely. Go to the part where mr. brian o'conner pops open his hood and everyone shits a brick. and the little nerdy kid starts talkin about t4 turbo's. then.... look at the engine. it's a 420a with a venom valve cover and a dress up kit. it's not even a gst. I've seen the car in person, its an eclipse rs. Sorry to go off on a tangent... I just find these things nice and humorous
V8's are like tampons, every pussy needs one!
Old 04-04-2004, 02:05 PM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
lol Sound like F&F.
Anyways Silver_GTR34, read the link dsm97gsx posted, i think it will help clear things up.
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 04-04-2004, 03:09 PM
ashah000's Avatar
Re: Re: Double-Clutching in GST/GSX?
That, and the fact that you can clearly see a header
Old 04-05-2004, 01:07 AM
KensEclipse KensEclipse is offline
Send a message via ICQ to KensEclipse Send a message via AIM to KensEclipse Send a message via MSN to KensEclipse
Step away from the dvd....
1991 Mitsubishi Eclipse GS-T
Old 04-05-2004, 01:32 AM
Hahahahahahahaha
Old 04-05-2004, 07:20 PM
my friend was watching too much F&F, he went on my SN in AF to ask you guys this question...sorri bout that, pshh...i aint another F&F follower...hahahaha
--2OF9--
#808/1000
Old 04-05-2004, 09:37 PM
CODE4 CODE4 is offline
Send a message via ICQ to CODE4 Send a message via AIM to CODE4
If you just rev match without releasing the clutch it eliminates the lurch but does nothing to spin up the syncros. It is agreed that double clutching in a race does little to help you. However if you are in a race that contains turns and you down shift in the beginning of the turn without matching the RPM, the car lurches forward, and you upset the weight balance of the vehicle and possibly cause an oversteer situation where the back end kicks out wide. When I am cruising around on the streets/highways and enter a turn and want to blow thru it I double clutch for the fun of it.
And if you practice double clutching, it can be pretty fast. Only those that never do it screw it up and make it look bad.
______________________________________________
1999 Eclipse RS
ET: 16.1 @86.241 | Speedworld Motorplex, Phoenix, AZ
Old 04-05-2004, 09:51 PM
ashah000's Avatar
Thanks
Old 04-05-2004, 11:59 PM
Igovert500's Avatar
blue + red light magnet
Code4 is correct. Just to add to it a bit, F&F makes people stupid just watching it. They were drag racing from a dead stop, they raced in a straight line, therefore there was no need to downshift, therefore no need to double clutch.
Doubleclutching is when while downshifting you
1. depress clutch and take it out of gear
2. let go of clutch
3. hit gas and match rpms
4. depress clutch and put in lower gear
5. release clutch
This is a good technique to use because it matches the speed of your synchros in your tranny, and prolongs their lifespan. With practice you can do it almost as fast as normal shifting. It is just a good technique to learn, and can/should be appied to ALL manual cars(turbo or non-turbo). In any situation (race or daily driving) when the need to downshift arises.
It is good on your car, prolongs your synchros, eliminates that lurching of downshifting, and saves you from whiplash...why not do it?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-06-2004, 12:46 AM
1999 Eclipse RS
